nodar1978 Posted May 6, 2008 Share Posted May 6, 2008 i'm working on these visuals, your comments or ..... please Link to comment Share on other sites More sharing options...
blade911 Posted May 6, 2008 Share Posted May 6, 2008 well done renders. but im not likin the colors. somethin abt it is dull. maybe the walls. try changin em to say a cream color o somethin. cheers Link to comment Share on other sites More sharing options...
Horhe Posted May 6, 2008 Share Posted May 6, 2008 The images look nice. I would say they need lighting up. Too dark at the moment. Try and make the grey walls more white. That will liven up things. Link to comment Share on other sites More sharing options...
nodar1978 Posted May 6, 2008 Author Share Posted May 6, 2008 guys is it really so hard to set the lightings in scene or its hard only for me? and is there any basic rools for vray lightings? my scen is always dark, and when i'm trying to make it lighter then i'm loosing the quality of realism. really need some help to step up from here thanks Link to comment Share on other sites More sharing options...
nodar1978 Posted May 6, 2008 Author Share Posted May 6, 2008 thanks guys for comments. and also one more question, usually clients very often asking me to switch light ON in day time, i don't know why but they do. could you give me any spetioal technique how to do it nice and easy in vray? thanks Link to comment Share on other sites More sharing options...
ap3 Posted May 7, 2008 Share Posted May 7, 2008 Hey finally vray!! smart choice, how you learn it, give me some idea I may try it. Thanks. Ann Link to comment Share on other sites More sharing options...
yorik Posted May 7, 2008 Share Posted May 7, 2008 I liked those images too... if it was me, i would try putting a common point light well in the middle of the room, give it a reach distance just a bit bigger than the room, so it doesn't affect too much the objects, make it not affect specularity, only diffuse, and give it a warm "beige" color, and turn shadows off... This way you would create a warm, soft, gentle light emerging from the center of your scene, that would "tweak" just a little bit the vray global illumination, making disappear a bit the dark grey areas. All the difficulty is to make it very, very smooth so you don't loose your nice GI... Just a little push... It is a very personal opinion, but might be useful... Link to comment Share on other sites More sharing options...
mskin Posted May 7, 2008 Share Posted May 7, 2008 Carpet scale seams odd to me, so does the concrete… too big, wood floor looks good. Also some tiling issues with the built-ins wood mat. Curtains are fantastic, furniture too (did you model?). There is a lot of attention paid to detail…. Pendant and can light fixtures, table fixtures, etc. It lacks any sort of “lived in” elements like books, magazines, things on the shelves – id love some paintings on the wall. What about some wash on the walls from lighting? Otherwise, the modeling is great, the lighting in my opinion seams to be accurate for a completely day lit scene, but like I mentioned before, how about some interior lighting accents. Good work Link to comment Share on other sites More sharing options...
ApeiNe Posted May 7, 2008 Share Posted May 7, 2008 Nice renders already You can for sure correct most of the lighting problems in post. You can also use a vray physical camera and tweak the settings to get something better. The impact of the sun is a bit to low i think, esepcialy on the last render. try maybe to increase the indirect illumination with bright/dark multiplier and lower the vraylights (plane) at the windows ( i guess you used it) so many different possibilties to get to the result. keep going Link to comment Share on other sites More sharing options...
Ismael Posted May 8, 2008 Share Posted May 8, 2008 Get HDR Shop v1 and Banty's Toolkit 1.5 Install and run your renders trough something like "Scan" plugin. It will give you an idea of what brighter may look like. I concur, the renders are way too dark... Link to comment Share on other sites More sharing options...
sudark Posted May 14, 2008 Share Posted May 14, 2008 wow nice renders! whats your lighting setup? and what did u use for color mappping? Link to comment Share on other sites More sharing options...
birdman67 Posted May 16, 2008 Share Posted May 16, 2008 The images look nice. I would say they need lighting up. Too dark at the moment. Try and make the grey walls more white. That will liven up things. I bet that physcam vignetting is set to 1.0, right? Try turning that baby down to 0.0 to start...could always add radial darkening in post Link to comment Share on other sites More sharing options...
birdman67 Posted May 16, 2008 Share Posted May 16, 2008 thanks guys for comments. and also one more question, usually clients very often asking me to switch light ON in day time, i don't know why but they do. could you give me any spetioal technique how to do it nice and easy in vray? thanks Try messing with the IES lights for starters...you can find profiles on the web or www.evermotion.org has a nice starter set in "free stuff." As for the lighting, every scene is different. This may be helpful for you: http://www.spot3d.com/vray/help/150SP1/tutorials_interior.htm Pretty straightforward, and if you understand the concepts here you'll get nice images with reasonable render times. Practice, practice, practice! Link to comment Share on other sites More sharing options...
