Trevor Tizard Posted May 7, 2008 Share Posted May 7, 2008 Hi, I'm looking for a piece of software that will take the bucket fill feature of MS Paint to the next level. Basically I want to import a line drawing (in some form of bitmap or jpeg) and bucket fill areas as I can in paint. However I want to be able to fill with paterns/bitmaps for wood, floor tiles, worktops etc. These patters should be both scaleble and rotateable. Ideally I'd like to have a library of fills to use. In essence I want to take a bitmap of a kitchen perspective view and add finishes to the doors, worktops, floor. Anyone have any suggestions. Thanks Link to comment Share on other sites More sharing options...
STRAT Posted May 7, 2008 Share Posted May 7, 2008 photoshop elements Link to comment Share on other sites More sharing options...
aaron-cds Posted May 7, 2008 Share Posted May 7, 2008 In photoshop, you can bucket fill areas. For your floor layer that you bucket fill, you can then use the pattern effect to replace the solid color bucket fill with a bitmap that you can scale and rotate. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted May 7, 2008 Author Share Posted May 7, 2008 Thanks to you both, However, am I right in thinking I'd have to define my wood or tile texture as a pattern to bucket fill, and if so how do I then rotate and scale it? Link to comment Share on other sites More sharing options...
aaron-cds Posted May 7, 2008 Share Posted May 7, 2008 Thanks to you both, However, am I right in thinking I'd have to define my wood or tile texture as a pattern to bucket fill, and if so how do I then rotate and scale it? Yes, but it's probably not that difficult. You can scale it in the effects menu for the pattern fill. You can rotate it by rotating the bitmap itself, just guessing. Link to comment Share on other sites More sharing options...
Antisthenes Posted May 8, 2008 Share Posted May 8, 2008 use a layer mask and a large pattern fill behind it then use the free transform (holding control on the corners when moving) to make it match/skew. Link to comment Share on other sites More sharing options...
