johnbeyer Posted May 8, 2008 Share Posted May 8, 2008 (edited) Hello, I'm kinda new to Vray. I have 1.50. All the plugins are loaded in the correct libary. when i start up 3ds Max it gives errors; Failed to initialize module : Vrayplane.dll VrayPshychcam.dll Vrayfur.dll VrayDome.dll and some more.. But when i click on ok at all of them, 3ds max loads fine and i am even able to use some components of Vray. i can render with it it and it looks very nice. Vray material works, Vray light works, but I don't see any other Vray thing or buttons around. What did i do wrong?. Some pictures i am working on.. I'm very noobish, sorry Edit : Also , I have such hard times creating realistic light. do they make realistic scenes with Global Illumination? Help would be so regarded. John Beijer Edited May 8, 2008 by johnbeyer Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted May 8, 2008 Share Posted May 8, 2008 Got that the other day also.. turns out something i installed screwed up my plugin.ini.. make sure it has both the Vray main path and the Vray Additional path. Link to comment Share on other sites More sharing options...
RobNJ73 Posted May 8, 2008 Share Posted May 8, 2008 Also , I have such hard times creating realistic light. do they make realistic scenes with Global Illumination? I found Evermotion's Archinteriors DVDs to be invaluable... they supply you with fully ready-to-render scenes that you can take apart and reverse-engineer. Link to comment Share on other sites More sharing options...
johnbeyer Posted May 8, 2008 Author Share Posted May 8, 2008 Thanks both of you. And yes, my ini file does show the paths correctly. Hm.. I will see if i can get that dvd but dunno if my dad wants to pay for a thing he might find worthless buying. Do one of you have any realisticly lightened scene i might use ? Thanks alot John Link to comment Share on other sites More sharing options...
Timbur Posted May 8, 2008 Share Posted May 8, 2008 check your plugin.ini in max folder. There should be V-Ray additional plug-ins- folder after the main plugins-folder.. if its above it, it gives errors when starting max. Link to comment Share on other sites More sharing options...
johnbeyer Posted May 8, 2008 Author Share Posted May 8, 2008 Hi, all i see is this ;=; [Help] mental ray 3.6 Reference=C:\Program Files\Autodesk\3ds Max 2008\help\mr_reference.chm [Directories] V-Ray additional plug-ins=C:\Program Files\Autodesk\3ds Max 2008\plugins\vrayplugins V-Ray main plug-ins=C:\Program Files\Autodesk\3ds Max 2008\plugins Link to comment Share on other sites More sharing options...
Timbur Posted May 9, 2008 Share Posted May 9, 2008 V-Ray additional plug-ins folder must be last. So change that ini to look like this. ;=; [Help] mental ray 3.6 Reference=C:\Program Files\Autodesk\3ds Max 2008\help\mr_reference.chm [Directories] V-Ray main plug-ins=C:\Program Files\Autodesk\3ds Max 2008\plugins V-Ray additional plug-ins=C:\Program Files\Autodesk\3ds Max 2008\plugins\vrayplugins Link to comment Share on other sites More sharing options...
johnbeyer Posted May 9, 2008 Author Share Posted May 9, 2008 (edited) Thanks a thousand! Really, thanks a lot, it doesnt give any errors anymore and i can use vray sun and everything. like a kid in a candystore. Edited May 9, 2008 by johnbeyer Link to comment Share on other sites More sharing options...
Timbur Posted May 9, 2008 Share Posted May 9, 2008 No problem mate! love to help Link to comment Share on other sites More sharing options...
fstun Posted May 23, 2008 Share Posted May 23, 2008 hi Timbur! i seem to have the same problem...itried everything you said but it still doesnt seem to work! > im on windos vista and i installed 3dsmax 2009 and it works fine.. i tried to install vray render but it reports errors during the installation so i installed manually by extracting the dlls in an other folder and afterward copying the into 3dsmax files... i chacked the plugins ini file and the paths are correct.. but every time i start vista i get the error message that the vrender60.dlr its ton intialised i attached screencaps i checked the plugin folder and the dlr exists...dunno what to do im desperate! thanx for your help Link to comment Share on other sites More sharing options...
fstun Posted May 23, 2008 Share Posted May 23, 2008 correction **** every time i start 3ds max i get these errors **** Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted May 23, 2008 Share Posted May 23, 2008 this has happened to a few different systems here for some reason, fixing the plugin.ini has fixed them all though, so thats good at least Link to comment Share on other sites More sharing options...
fstun Posted May 23, 2008 Share Posted May 23, 2008 it doesnt work for me .. Link to comment Share on other sites More sharing options...
Timbur Posted May 26, 2008 Share Posted May 26, 2008 fstun, do you have the sp2 version of the vray? I don't know for sure if the older versions work on max 2009. Link to comment Share on other sites More sharing options...
moonrathna Posted March 20, 2009 Share Posted March 20, 2009 Thanks for the solution... Then what to do with missing dlls - rpc.dlo. could any body help Link to comment Share on other sites More sharing options...
Timbur Posted March 22, 2009 Share Posted March 22, 2009 Thanks for the solution... Then what to do with missing dlls - rpc.dlo. could any body help Hi! If I remember correctly, rpc.dll error comes if you have rpc objects in your scene, but you don't have those plugins installed... So if you dont need those rpc objects just delete them and save your scene. And if you need those, you should check http://www.archvision.com/ Link to comment Share on other sites More sharing options...
