nodar1978 Posted May 8, 2008 Share Posted May 8, 2008 guys maybe stupid question, but what is best way, if you have lots of materials in scene and mtl editor window 6x4 is not inough? I'm using pick material fro object and then changing and ..., but maybe there is an easier way? thanks Link to comment Share on other sites More sharing options...
mattclinch Posted May 8, 2008 Share Posted May 8, 2008 i use the 'get material' button and then select 'from scene' and choose one. gotta have them nicely named obviously. Link to comment Share on other sites More sharing options...
nodar1978 Posted May 8, 2008 Author Share Posted May 8, 2008 thank you, exactly what i wanted thanks Link to comment Share on other sites More sharing options...
louis.cho Posted May 9, 2008 Share Posted May 9, 2008 It's a shame that autodesk make it 6x4 max. I all my scenes use way much materials. They should be displayed 6x99 with a slider! Link to comment Share on other sites More sharing options...
Justin Hunt Posted May 9, 2008 Share Posted May 9, 2008 No need for more, 1 or 2 is more efficient, uses less memory too. Dont forget that you can drag and drop a material from one slot to another to copy it. just remeamber to rename the copy A often over looked tool is the material library jhv Link to comment Share on other sites More sharing options...
nodar1978 Posted May 10, 2008 Author Share Posted May 10, 2008 thanks guys Link to comment Share on other sites More sharing options...
