Lhanh29 Posted May 9, 2008 Share Posted May 9, 2008 I have the option with server for my workstation like below: Please give me advice. Is it reasonable for 1 server.I have 8 quadcore 6600 desktops personal.i need the server link all of them.Thanks 5U Tower Server E537-X2QI Rackmount - Processor: 1x CPU Quad-Core Intel Xeon Processor 5420 (2.50GHz) 12Mb L2 – LGA771 - Bus 1333 MHz, 64Bit S/p - MotherBoard: Intel® Server Board S5000VSA Fully Buffered Support 1333/1066/667Mhz (Support 2CPU) - Chipset: Intel Intel® 5000V server chipset 800/1066 MHz - Vga : ATI* ES1000 with 16MB SDRAM memory - Integrated SCSI: Intel® Server Board S5000VSA Enhanced SATA (3Gbps) provides six ports and RAID 0, 1, 10 (Optional AXXRAKSW5 for RAID 5) - I/O slots: Four/ Eight Fully Buffered DDR2 533/667 MHz DIMM, 2x PCI Express x4 (x8 Connectors), 2x PCI-X 64-bit/133 MHz, 1x PCI 32-bit/33 MHz - Integrated LAN: 2 x Intel Gigabit Ethernet connections - Memory: 1x Wintec 1GB PC5300 ECC Fully Buffered DIMM DDR2 (Heatsink inclusive, Max 16GB, Options 32GB) - Hard Disk : 1x Seagate 160GB Sata 7200 rpm, Hot-swap (Options HDD SATA/SAS 10.000rpm/15.000rpm) - CDROM/Floppy : Non CD. Non FDD (Options). - Chassis: Server Platform Chenbro S106 with + Backplane : 1x 6 port SATA/ SCSI Hot-swap (Options) + Hotsbay: 6 hot-swap drives (SCSI or SATA) + System cooling fans: 1x B1248 system fans + Power Supply: 1x 600watt PSU OEM Chenbro. + Dimension (WxHxD): 533mm x 198mm x 425mm (5U). Link to comment Share on other sites More sharing options...
