RAYMOND Posted May 9, 2008 Share Posted May 9, 2008 how do you move walls so they are snaped into place most of my walls seem to be off... also seen no construction grid option r:D Link to comment Share on other sites More sharing options...
Horhe Posted May 10, 2008 Share Posted May 10, 2008 Umm... could you be more specific? You toggle on snap and just snap... Link to comment Share on other sites More sharing options...
IHAB Posted May 10, 2008 Share Posted May 10, 2008 construction grid is under the basics pull down menu or you can find it under " drafing ", revit has a cool UI , you will soon get used to it you will have to draw all the const. grids individually or by using the offset option from the tools bar and clicking on the arrow icon. Link to comment Share on other sites More sharing options...
Horhe Posted May 10, 2008 Share Posted May 10, 2008 Ahh... sorry my mistake... didnt read carefully what program this question was allocated to... Link to comment Share on other sites More sharing options...
RAYMOND Posted May 10, 2008 Author Share Posted May 10, 2008 thanks that helped... i am used autocads snap and grid... however I did have kinda ??? time trying to move the wall ends to a snaped position. also the arrow keys don't seem to snap to anything most of my walls are not located exactly where they should be and dims are off not to a clean rounded off to inches... not sure how all this got this way well I have spent 2 days with Revit how on earth can we post RVT files since they get so huge.. r;) Link to comment Share on other sites More sharing options...
IHAB Posted May 11, 2008 Share Posted May 11, 2008 youre right , file reaches up to 50mb and becomes too slow for editing ,even if you are editing 2D & not intending to get a 3D out of it Link to comment Share on other sites More sharing options...
kris McIsaac Posted May 22, 2008 Share Posted May 22, 2008 You can use the dimensions to move the walls into the exact location. Select the wall and any dimensions associated with it will turn blue. You can then add the correct value of the dimension and the wall will move. Just be careful that you dont have floors and roofs move with it. Link to comment Share on other sites More sharing options...
