own1221 Posted May 13, 2008 Share Posted May 13, 2008 Hey i'm trying to get this effect (attached image) What setting do i use for the frosted glass ? any suggestions for the lighting setup? it seems like there is a light behind the person which might help. Thanks Link to comment Share on other sites More sharing options...
own1221 Posted May 18, 2008 Author Share Posted May 18, 2008 have I posted in the wrong section? noone is replying Link to comment Share on other sites More sharing options...
Eric Sosa Posted May 18, 2008 Share Posted May 18, 2008 (edited) hey Owen, vray mat with some refraction (dark gray) and ligth blue with 0.002 fog, afect shadows & gamma, besides, a vray ligth behind the human figures with shadows with 15 subd. make some tries...u'll get it to work, I'm positive beware that, by altering the defraction of the vray mat, the render time will increase significantly....this is the price of using "half translucid" materials. other option is to use "noise" on the mat difuse map...tho it does not look good for close ups, besides it could be more a hazard then help trying to make it look good....if you are not familiar with vray mat versus vray setups. good luck Eric Edited May 18, 2008 by Eric Sosa Link to comment Share on other sites More sharing options...
shaneis Posted May 18, 2008 Share Posted May 18, 2008 (edited) Here you go, http://www.evermotion.org/vbulletin/showthread.php?t=58359 Flick through the post at above site and he gives the details of his lighting and render setup. S. EDIT: Replaced the link with one that works...sorry 'bout that Edited May 19, 2008 by shaneis Fix link Link to comment Share on other sites More sharing options...
shaneis Posted May 19, 2008 Share Posted May 19, 2008 From 3Seventh's evermotion post: * direct light for the sun and Vraylights placed in the windows. * LC + Irrmap (high preset with Detail Enhancement) and linear workflow for the tonemapping. *The frosted glaz is fifty percent greenish grey with fifty grey too refract value and glossy refractions * Spotlight RGB R: 255, G: 205, B: 128. * Volume lighting was done with a real volumetric layer + a few PS retouches G'luck S. Link to comment Share on other sites More sharing options...
