Plgin Error "vraysimbiont90.dlt" failed to initialize
danb4026
I am getting this DLL error everytime I start max and cant figureout what is causing it.
"vrayplugins\vraysunbiont90.dlt" failed to initialize. Error code 14001 - The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail."
Anyone seen this before and have a fix?
Hello,
I had this error message and after searching the chaosgroup forum, I found out that you can simply delete this file (unless you want to go and play inside the code or something no artist will risk on doing ;)) and Vray will be just fine without it.
Cheers,
