RAYMOND Posted May 15, 2008 Share Posted May 15, 2008 don't see an option to add custom hardware like handles and hindges to door... also don't see how you swing a door open in a 3d view?:confused:r Link to comment Share on other sites More sharing options...
kris McIsaac Posted May 22, 2008 Share Posted May 22, 2008 Both can be done by editing the door family. You can add the hardware to the door or add it as a component. You can set it to only display in 3D. I havnt done this wet but I think you can attach your door leaf to a reference plane and add an angular dimension to this with an instance parameter. Once you load the door back into your project you can adjust the angle in the object properties Link to comment Share on other sites More sharing options...
