rgb values?
SgWRX
i feel like a dork for not looking this up before i "need" it, but why can't i get rgb values in an arch&design diffuse color swatch when i click on the color selector? for instance 192 red is what decimal value? must be a way to change it?
thanks
Yes. :) Don't feel like a dork. Since the A&D materials use 0 to 1 values, there's a way around that (thank you, Bri at www.mentalboutmax.com !!)
Open your material editor
get your a&d material slot 'ready'
open a 'blank' generic (non-A&D slot next to it)
click the diffuse colour to enter the RGB values in the blank generic slot
ok - the colour is now set.
right-click the diffuse colour and then pick copy
click and select the A&D shader material slot
right-click on the COLOUR slot under the MAIN MATERIAL PARAMETERS rollout at the top and select paste
ta da
:D
Hit Ctrl-N with the spinner highlighted.
This will pop up a window where you can enter mathematical expressions which will be pasted to the spinner on completion.
type (yourvalue/255.0) to convert 8-bit to float, or (yourvalue*255) for the other direction.
