how to remove the too perfect look
Three D
hi. is there a modifier, script, plugin, shader etc. available that will modify the edges of my model to remove the unrealistic look of perfectly straight sharp edges? i've searched a number of forums and script/plugin sites but found nothing that does what i need. thanks.
if you use the MIA materials, just click on rounded corners (under AO)...should work. There used to be a chamfered edge script back in v5 or so, but i have no idea if anyone packed it for the newer releases. You can also chamfer your edges on the model itself.
