Help with VraySpawner...Please!!
danb4026
I have looked everywhere and cant find a solution that works. I have max 2008 and vray 1.5 sp2. Spawner will not stay open on my slave machine. I have gone thru the backerburner manager/server process on both manager and server machines.
Can anyone provide some much needed help?
Is this a new/different problem than the one you brought up in another thread? Or are we talking about the same problem in two threads?
Either way, (and I'm not 100% positive about this point) if you're running your DR through Backburner I don't think you need to run VRay's DR spawners. Backburner should be able to see that you have the plugin installed and handle it accordingly.
I run my DR at work using just VRay's DR (the spawners)... no Backburner. I'll only use Backburner instead of VRay's DR if I need to queue up more than one rendering from more than one file in one sitting.
Maybe that's where the trouble is coming from... running both at once?
