Mike. Posted May 17, 2008 Share Posted May 17, 2008 (edited) i made a mistake whith the title of the thread sorry. i m new to this forum . here is a pic of a house in africa,raw render. i have to make 10 views of it. this is the first. i'll post updates soon (i hope) for the moment i have a problem whith THE DAMN GRASSSS. you can see i used displacement for the grass.and you can see it doesn't work. i tried to tweak it to the desired results whith no success. I tried vrayfur takes ages to render. I tried built in max fur convert to geometry, not good result. Would you have a tip for the displacement map ? for the moment i'll tweak again and again .... anyway this is it for the moment.comments welcome Thanks Edited May 17, 2008 by Mike. i made a mistake whith the title of the thread sorry. Link to comment Share on other sites More sharing options...
RODRI Posted May 17, 2008 Share Posted May 17, 2008 nice render. may be the glass at right needs + transparent. i like the wood. Link to comment Share on other sites More sharing options...
WAcky Posted May 18, 2008 Share Posted May 18, 2008 I reckon it looks pretty good actually. Maybe try mixing your disp map with a large noise map to make some variation in length over a larger scale... Link to comment Share on other sites More sharing options...
chadw Posted May 18, 2008 Share Posted May 18, 2008 I didn't even notice the grass.... so I would so say it's pretty good. However the crushed stone does not seem to have enough resolution next to the wood. The wood has lots of detail and the stone is blurring out. That is what caught my eye. Nice image all in all. Link to comment Share on other sites More sharing options...
selos69 Posted May 18, 2008 Share Posted May 18, 2008 Hmm, not sure what you mean by 'not working' because it clearly is and i think it looks quite nice actually. As the others have said, try adding a noise modifier to the grass plane and smooth it out. I also think maybe you should crank up the contrast of the decking a tad (look for 'colorcorrect' plugin for the easy way). If your working in LWF make sure the Bitmap was imported at 2.2 gamma The glass would look better if it were a bit more transparent also. Im not sure what the white material is on the right? You might want to work on that a little more. - if it was a painted concrete, you might want to add a slight bump and perhaps a mapped reflection? Check the mapping of the stone. I think it's very much on the way of being a really good render. Fantastic design, excellent camera position, excellent lighting. Link to comment Share on other sites More sharing options...
Mike. Posted May 18, 2008 Author Share Posted May 18, 2008 Thanks all for your attention. I'm actually fighting whith gamma. (god wanted i discover this thing just two days before i have to give my image to the client, what a brain pain.) i 'm trying the big noise displace thing, and i hope i'll opst updates soon. Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 18, 2008 Share Posted May 18, 2008 There's a very good thread on Gamma on this site. From what I can gather: F10 -> Renderer tab -> Preferences -> Gamma and LUT If you save to a JPG, TIF, BMP, any-8-bit-format, set OUTPUT GAMMA to 1.8 If you save to a HDR, EXR, or any 32-bit format, set OUTPUT GAMMA to 1.0 I think your render is wonderful - just the comment about the white concrete area on the right. Link to comment Share on other sites More sharing options...
Horhe Posted May 18, 2008 Share Posted May 18, 2008 Looking good. Grass could be a tad brighter and a little less saturated IMO. Link to comment Share on other sites More sharing options...
Mike. Posted May 18, 2008 Author Share Posted May 18, 2008 (edited) Thanks for the replys guys. I am a little bit in a hurry, and this gamma thing just tortured me for the last two days. now it is ok, but i think i won't have time to bring all the needed modifications (correct the white thing on the right of the first pic or make a nice grass....). Anyway, here are two more images. Comments welcome and needed especially if you have ideas about the sky , colors and tints in the two new images, which hurt me a little bit but i don't know exactly what to change. Thanks Edited May 18, 2008 by Mike. Link to comment Share on other sites More sharing options...
RyanSpaulding Posted May 18, 2008 Share Posted May 18, 2008 There's a very good thread on Gamma on this site. From what I can gather: F10 -> Renderer tab -> Preferences -> Gamma and LUT If you save to a JPG, TIF, BMP, any-8-bit-format, set OUTPUT GAMMA to 1.8 If you save to a HDR, EXR, or any 32-bit format, set OUTPUT GAMMA to 1.0 I think your render is wonderful - just the comment about the white concrete area on the right. Where did you read this? Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 18, 2008 Share Posted May 18, 2008 From here: http://www.cgarchitect.com/vb/29852-help-needed-understanding-gamma-lut-correction-4.html Fantastic render! Link to comment Share on other sites More sharing options...
Mike. Posted May 18, 2008 Author Share Posted May 18, 2008 From here: Fantastic render! thanks ! about gamma, this is what i do. 2.2 everywhere gamma, input and output. convert all your textures to gamma 2.2. keep vray color mapping gamma to 1.0. that's it. lol.... all this brain pain just for that. my max screen is then the same as my photoshop screen, which is the same as my printer output. Under Controllll . (since today only) Link to comment Share on other sites More sharing options...
Trevor Tizard Posted May 19, 2008 Share Posted May 19, 2008 These are nice images. They just need a little curves correction in PS as they are a touched washed out (although this is quite normal with LWF). Link to comment Share on other sites More sharing options...
Mike. Posted May 19, 2008 Author Share Posted May 19, 2008 here are some of the 10 view i had to do for the client. 8 days of work. i didn't have time to push things as far as i wanted, but i'm quite ok with the result. thanks for having participated in this thread. ps: lwf rules see you next time Link to comment Share on other sites More sharing options...
Ky Lane Posted May 19, 2008 Share Posted May 19, 2008 Dude, if thats your idea of bad grass... cant wait to see your idea of good grass! Link to comment Share on other sites More sharing options...
Mike. Posted May 20, 2008 Author Share Posted May 20, 2008 (edited) Dude, if thats your idea of bad grass... cant wait to see your idea of good grass! i'm looking for natural grass like this for example. i guess i'll forget 3d grass for the moment as i didn't find any good technique.... Edited July 12, 2008 by Mike. More appropriate... Link to comment Share on other sites More sharing options...
