Good Interior Renders?
iaga
Is there anyone that can advise me on workflows, lighting etc. for a decent interior shot. I currently use Viz2008 and VRay SP2 . I have the model setup already but I need to know how to work out good lighting techniques that I need help on.
In addition do I need to sort out a clay render first before I start applying the materials? I have attached some test images of a college that I am working on - the white renders are just with VRAY GI and the interior has a few VRAY plane lights with a white override material.
All help much appreciated.
I started with vray, with following instructions, of course is just a begining....
global switches - disable default lights
indirect ilumination - on
Primary Bounces: Irradiance map / low preset /show direct light ON
secundary bounces: qmc
(at this point only windows are visible, and everything looks dark)
Add a Vray light with similar size to the window.
light must be inside the room, leaving a small gap.
vray ligth properties: as default with following exceptions:
activate:
on
invisible
ignore light normals
smooth surface shadows
color: light bluish
multiplier: 25
(at this point, light with look very strong and brighter as wished)
to correct this:
G-Buffer color mapping: color mapping type: exponential
dark multiplier: 1.0
affect background: uncheck
Add Sun light : Target direct above the roof pointing toward the window
shadow type: vray shadow
multiplier: 7-10
color: light yellow
image sampler (antialiasing)
adaptative subdivision -2 y 1 (fast, low quality)
Min rate -1 max rate 2 (slow but better)
just one more question - what would you do about the ceiling? as it still remains slightly dark... Would you put additional VRAY lights or a plane light to cover the whole ceiling?
