neeed help. please. dark net renders
FORM3D
Hi folks.
Got a bit of a problem…
See the two attached images. One is rendered simply in Max9 with Vray (sp1). the other using the net render….
The one done in net render is much darker and the colures not the same??
Has any one any ideas why this might be??
Any advice is hugely appreciated.
Matt.
HI there.
Yep if I where using two different machines I would have deduced something similar but I’m only rendering on one machine when this problem arises.
Same machine two different renders..?
Doing tests in Max , then had planed to stack up a sequence of paths in backburner .
im using max 9 sp2 and vray sp1 on a brand new vista machine.
by the by .... i hate vista.
There are various reasons I would chose to render via BB rather than straight from Max.
If you have limited hardware and say an animation Ir map and long sequence of frames to render then the best way is to que them up in back burner to render over night .
Or if you where rendering a large still it is often advantageous to render strips.
also i often find that a scene that would crash out max will render without problem if sent via backburner.
(not this time however.)
There you go three good reasons.,
