RMdecor Posted May 20, 2008 Share Posted May 20, 2008 Hi everyone, Does anyone know how to take a 2d elevation and wrap it around a circle to make a ring? Attached is a sketch my client gave to work with. The bottom part is the elevation and the top is the plan view. Thank you. Rachel Mallon Ironwood Design Studio Link to comment Share on other sites More sharing options...
Claudio Branch Posted May 20, 2008 Share Posted May 20, 2008 Just crop the view out in Photoshop and save it as a texture. Then you can create a cylinder in Max add a UVW Map (select Cylindrical mapping) and finally assign your texture to the object. Link to comment Share on other sites More sharing options...
RMdecor Posted May 20, 2008 Author Share Posted May 20, 2008 Thats a good idea thank you. Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 20, 2008 Share Posted May 20, 2008 Claudio Branch said: Just crop the view out in Photoshop and save it as a texture. Then you can create a cylinder in Max add a UVW Map (select Cylindrical mapping) and finally assign your texture to the object. Claudio - they should build a statue for you! Link to comment Share on other sites More sharing options...
Claudio Branch Posted May 20, 2008 Share Posted May 20, 2008 Link to comment Share on other sites More sharing options...
Claudio Branch Posted May 21, 2008 Share Posted May 21, 2008 (edited) Claudio Branch said: Then you can create a cylinder in Max... I thought I was in the Max forum (). Luckily, the advice still applies in AutoCAD 2008. Create a circle, Extrude it and go to Materials (View, Render, Materials) to assign your image to the cylinder. The material mapping controls are built in to the Materials dialog box. You can also explode the extruded object if you want to delete the top and bottom surfaces. The trick here is to use a circle whose perimeter (p=diameter*pi) is equal to your image width and its extrusion height equal to your image height. Proportionally speaking... Edited May 21, 2008 by Claudio Branch Link to comment Share on other sites More sharing options...
