Symbols and components
YOHKOH
Hi
I am fle linking a dwg 3d model which has come from vector works.
In vector works we cna create 3d symbols which can be copied around the drawing and when one is updated they all are. Same as instancing.
The problem I have is when i file link the DWG to max.
These objects retain their symbology, ie universal editability but if I move them they all move. Even though I'm not within edit poly.
It is as if within the info stored as symbols they retain XYZ position info and translate this to max. This is not seen in VW.
Even if I bind the dwg to max the objects move with each other as if they have a contraint attached
Any help would be appreciated.
Thanks
Edited by YOHKOH
never used vector works before, but if you import a DWG from autocad, any geometry on the same layer will be treated as one object. If you want to move the pieces individually you need to go into your mesh edit and use the sub object or face selection to move them.
