markf Posted May 22, 2008 Share Posted May 22, 2008 I am trying to adjust the path in a loft. I cannot see the bezier handles of the vertex when selected. If I move the cursor around and get lucky I can mange to get a hold of a handle and move it to adjust the path curvature. But I cannot see the handles in the viewport. This is causing me much aggravation. Anyone else experience this and have any solution? Thanks. Link to comment Share on other sites More sharing options...
Tyorl Posted May 26, 2008 Share Posted May 26, 2008 Try to "Put" your path as instance and align it with your loft. Link to comment Share on other sites More sharing options...
markf Posted May 26, 2008 Author Share Posted May 26, 2008 Thnaks for the suggestion, I'll give it a try. It occured to me that this may be a good reason to not delete the path used to create the loft. If I still had the original path perhaps I could adjust it rather than trying to adjust the path that is embedded as a sub object of the loft. Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted May 26, 2008 Share Posted May 26, 2008 sometimes, i don't know why, the bezier handles dissapear, mostly when converting from linear vertez to bezier or bezier-corner. the solution is select he vertex, right click over it, and select "reset tangents". good luck. Eduardo Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 26, 2008 Share Posted May 26, 2008 Thnaks for the suggestion, I'll give it a try. It occured to me that this may be a good reason to not delete the path used to create the loft. If I still had the original path perhaps I could adjust it rather than trying to adjust the path that is embedded as a sub object of the loft. Yes. That's the power of loft and sweep - to take the complex shape that results and 'go back down' to one of the primitives and modify it easily. I usually keep my shapes on their own layer and when I don't need them, hide the layer. Link to comment Share on other sites More sharing options...
markf Posted May 26, 2008 Author Share Posted May 26, 2008 Thanks for your suggestion. I did try that "reset tangents" but it had no affect. I also should mention that I created the loft (of a curb and gutter) and then added some vertices to this path to make it conform to a revised layout. So maybe it's especially problematic with pathe that have had vertices added after the loft was created? Thanks again. Link to comment Share on other sites More sharing options...
