SandmanNinja Posted May 25, 2008 Share Posted May 25, 2008 Hi... I tried a few tips and tricks and walk-throughs on here to get my 2:1 ratio spherical JPG converted into a QuickTime movie. I finally decided upon PanoCube and I downloaded all the files and copied DLLs to system32, etc, and it makes a MOV and a HTM file, but the QuickTime player is just blank when I browse to it online or run it from my hard drive. I had a flash of inspiration and fired up my laptop (which has XP Pro) and copied the PanoCube folder from my QuadCore's c: drive to it's c: drive. It converted the file fine and when I double-clicked the HTM, I could see the interactive QuickTime just fine! I quickly copied the 2 files to my memory stick and shut the laptop down properly before the batteries went flat. I whacked them back onto the QuadCore and - still cannot seem them even though I have QuickTime Pro 7.x installed. Thinking it's just a 64-bit incompatibility issue, can I ask someone to check my logic and my interactive QuickTime and tell me if it viewable on their particular setup and what that setup is (i.e. Windows XP Pro, IE7)? If it is a 64-bit incompatibility, has anyone heard if Apple wants to tap into the remaining 90% market share and release a version for 64-bit? Here is the link: http://www.dhimaging.com.au/3D/ArchViz/vt1/PAN-01B.htm Thanking you... Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 25, 2008 Author Share Posted May 25, 2008 21 views and no one can click the link and say "Yeah it works" or "no it doesn't"? Sorry - just been trying to figure out a solution (if there is one) and a bit frustrated. Any feedback on the quicktime is appreciated. Link to comment Share on other sites More sharing options...
rawla Posted May 25, 2008 Share Posted May 25, 2008 Quicktime is not supported for 64 bit OSes. Both WinXP & Vista Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 25, 2008 Author Share Posted May 25, 2008 Thanks Rawla... sigh. That's really too bad. I emailed a few mates and they all have Vista (32 and 64-bit) and none of them can see it at all. The opening splash screen for QuickTime, but that's it. I even tried VLC, but it just quickly plays all 6 'sides' of the image and then stops. That's a real bummer. That pretty much closes the door (for now, at least) on even the Model Object rotation, so you can look at a model from many angles and have the camera rotate around it. I wonder if Microsoft's Silver Light will fill in the niche? I've installed it, but I've never been to a site (that I know of) that ever uses it. Thanks again Anuj. Link to comment Share on other sites More sharing options...
Logitek Posted May 25, 2008 Share Posted May 25, 2008 Hello Joel, I have the same problem here. WinXP 64 is really annoying with quicktime AND Flash (I can't see most websites done with the latest version of flash ) For my Quicktime VR, I found a very very VERY nice tool : http://www.devalvr.com/paginas/productos/index.html The interface and navigation is sooooo much better and more fluid than Quicktime. Check it out, it's free. Keep making the .mov with Panotool, then drag and drog your .mov onto the DevalVR player, and enjoy! Cheers, Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 25, 2008 Author Share Posted May 25, 2008 That works SO WELL!!! nice and smooth!! I still have to figure out how to change the HTML to get the browser plug-in to work right, but it's SOOOOO nice! THANK YOU! Link to comment Share on other sites More sharing options...
Logitek Posted May 25, 2008 Share Posted May 25, 2008 I still have to figure out how to change the HTML to get the browser plug-in to work right To be honest, I haven't tried to put this into a webpage yet. But if you find out (if it's somewhat tricky), I wouldn't mind you posting how you did it and yes, I love this little viewer! ...especially full screen with no frame! cheers, Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 26, 2008 Author Share Posted May 26, 2008 I've been able to drag a .MOV file into a web browser and it play. I've also been able to double-click a web page LOCALLY and get the embedded file to play. Can't do it on the net yet. Just got a bunch of tutorials and material for my second week of my online ArchViz class, so the quicktime web page project will have to wait a few days. But if it plays LOCALLY from my c: drive, then it should be playable online. I'll let you know how I go. Here is the stripped down HTML file: If you come across a solution, please post. Thanks! Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 26, 2008 Author Share Posted May 26, 2008 And the above example now works online!! http://www.dhimaging.com.au/3D/ArchViz/vt1/PAN-01B.htm it loads a really big window and I can smoothly pan around. So Very Happy. I used the code above. I think I needed to reboot my computer to get the plug-in to work. And the full screen mode is SO SWEET! Link to comment Share on other sites More sharing options...
Logitek Posted May 26, 2008 Share Posted May 26, 2008 And the above example now works online!! Hello Joel, I'm afraid this doesn't work with WinXP 64bits Did you use the plugin from devalDR? I don't think so. from your HTML code, it looks like you just placed your .mov inside the webpage. Sorry for the bad news Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 26, 2008 Author Share Posted May 26, 2008 Hello Joel, I'm afraid this doesn't work with WinXP 64bits Did you use the plugin from devalDR? I don't think so. from your HTML code, it looks like you just placed your .mov inside the webpage. Sorry for the bad news Hmmm weird. It worked for me. I took the html that panocube made and stripped out the extra commands that may confuse devalDR and then I browsed to it. So it does not work for you? Do you have the web plug-in? I am using the Developers Web Plug-in for Mozilla and it works a treat. Link to comment Share on other sites More sharing options...
fiero Posted May 30, 2008 Share Posted May 30, 2008 Hello all, SandmanNinja, you can use this script to configure your page easily (sorry, I'm new, I can't post links in this forum), enter in devalvr site (products page) and you can see the detectvr ZIP package. In the package you can see some examples, but you only need the file "detectvr js", place this file in the same folder that your MOV file. I can't post a link here, how could send you the code of html ? With this code DevalVR will be used always in Windows systems and QuickTime will be used in MacOSX regards! fiero Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 30, 2008 Author Share Posted May 30, 2008 THanks Fiero! I'll have a play now that it's the weekend. -Joel Link to comment Share on other sites More sharing options...
