Moving Objects
Hi
I am just wondering is there a simple method to move an object up on the
y axis a set distance. I currently have an object at position
X = 0, Y= -1003.272, Z = 0.... an want to move the object up 15cm.
Can this be done without having to add the 15cm to the -1003.272?
I tried holding shift down and moving up manually but it moves up at
increpments of 10. Can this be change to increments of 5? And is that
the simplest way of doing this?
Thanks
yeah...there is a easier way... go to bottom of the screen, next to your lock, on the right hand side there is an icon "Absolute mode transform", click on that type in numeric value that you want to move and voila (under Y), oh and make sure you are in the elevation view when you are doing it... That should sort you out...
rather than working out what -1003.272 + 15 is and then inputting that in the coordinates box you can click the text cursor in the coordinates box that you want to alter after the text and the unit and type in + (or -) 15 (or whatever number) and hit enter. This will add or subtract the typed in number and edit the position of the object.
Note: My example is obviously in the x axis but this basic adding and subtracting process works in all Cinema 4D numerical boxes.
Edited by BillyElNino
I forgot!
Hi
Thanks
hi there are 2 ways i can think of
1) just add +x in the Coords Manager.
x is the moving distance.
c4d will do the math for you.
2) click the move icon, go to Attribute Manager->Snap Settings->quantize->set the desired movement.
this will effect every movement from now on.
hth,
george
edit: sorry, i didn't see the posts above.
i got a new lazy mouse that doesn't like to scroll :)
Edited by gdrakakis
