Ruprect Posted May 28, 2008 Share Posted May 28, 2008 I am trying my first model using the loft modifier after always in the past creating walls by extruding linework created in CAD. I am fine with box shaped objects, creating a simple spline in cad to represent the wall and the fascia and applying it to the floorplan. I can't get my head around how I am going to use this method to create the gable. Is it possible to do this using lofts, or am I better of going back to extruding for this? Link to comment Share on other sites More sharing options...
Jim Mann Posted May 29, 2008 Share Posted May 29, 2008 I am trying my first model using the loft modifier after always in the past creating walls by extruding linework created in CAD. I am fine with box shaped objects, creating a simple spline in cad to represent the wall and the fascia and applying it to the floorplan. I can't get my head around how I am going to use this method to create the gable. Is it possible to do this using lofts, or am I better of going back to extruding for this? Can you sketch what you are trying to create because I can't think of a reason why you would want to use lofts for walls...at least not if I think I understand what you might be trying to do. Jim Link to comment Share on other sites More sharing options...
