Inxa Posted May 29, 2008 Share Posted May 29, 2008 Hello, Here's another go at Exteriors. I got the model from a ever library which a friend shared with me. This is used only for studies. Lighting is basic - Environment with blue light and one direct light for sun light. Color mapping - Reinhard. I am still trying with displacement for grass. Thanks a lot to Kippu for all the help. What do you think guys, how does it look. How can I better it. Link to comment Share on other sites More sharing options...
dave013 Posted May 30, 2008 Share Posted May 30, 2008 Firstly you should bump up the AA settings and use a much finer displacement for the grass. Some more objects or a plane with a texture behind the camera so there is more in the window reflections.Looks Good so far. Keep working on it. Link to comment Share on other sites More sharing options...
Orchid_Andy Posted May 30, 2008 Share Posted May 30, 2008 I like the plants surrounding the building:) Link to comment Share on other sites More sharing options...
Neil_cg Posted May 30, 2008 Share Posted May 30, 2008 Darken the white on those walls - true white doesnt exist, it's usually at around 235 all round (out of the 255 rgb scale) Link to comment Share on other sites More sharing options...
Inxa Posted May 30, 2008 Author Share Posted May 30, 2008 Hello, Sorry I forgot to mention it was a test with low-setting and AA not on. I have now placed a plane behind the camera for the reflections as well. The vraydisplacement is eating my head out Updates soon. Thanks Dave, Orchid and Neil. Link to comment Share on other sites More sharing options...
Inxa Posted May 30, 2008 Author Share Posted May 30, 2008 Here's a update. I did some lights on the wall and a table, couch and couple of chairs. Also, followed dave's suggestion, and applied a cityscape on a plane and placed it behind the camera. VrayDisplacement is not on. Again low-renderings settings. AA is not on. Link to comment Share on other sites More sharing options...
nelpiper Posted May 30, 2008 Share Posted May 30, 2008 Working with grass is quite tricky. Be carefull with the tiling. You can see the paterns. Also, it's not displaced enough now. The rest looks good to me. Refine it. Good luck. Link to comment Share on other sites More sharing options...
Deadponny Posted June 4, 2008 Share Posted June 4, 2008 Hey... i think that the 1st grass was better.... i'd just place some floor around the pool... Link to comment Share on other sites More sharing options...
Orchid_Andy Posted June 5, 2008 Share Posted June 5, 2008 I think the grass on the updated one is much better. ___________ http://www.orchid3d.com Link to comment Share on other sites More sharing options...
alfienoakes Posted June 5, 2008 Share Posted June 5, 2008 Its way too bright still.. Almost blown out. The glass looks good now, but without displacement, the grass is now obviously tiling.. Without that and the AA not being on.. its sort of really is a WIP image... Render a better quality one with Disp' and AA on, then we can see how it really looks. Link to comment Share on other sites More sharing options...
mayamax Posted June 5, 2008 Share Posted June 5, 2008 I have Some Problems in this image.. 1) I think The Shrubs Below The Window .. 2) The grass Map...its Tiling... 3) No displacement To grass 4) Swimming pool water ..looks to flat.. 5) walls are looking over bright 6) the colour of water ..i think its must be a slightly more green tinch.. I hope This Will Help You.. Link to comment Share on other sites More sharing options...
jinsley Posted June 10, 2008 Share Posted June 10, 2008 Getting better, I find the shadows to be a little sharp... softening them up a bit would help alot. Link to comment Share on other sites More sharing options...
RodT Posted June 11, 2008 Share Posted June 11, 2008 I would reccomend an apron around the pool. The water would be a mess with all the debris that would be tracked into the pool. Others have pointed out my other concerns Link to comment Share on other sites More sharing options...
sardesign Posted July 8, 2008 Share Posted July 8, 2008 bring the thick grass back looked great. i like the over exposure... reminds me of miami. Link to comment Share on other sites More sharing options...
