karolisbilz@yahoo.com Posted May 29, 2008 Share Posted May 29, 2008 here we go again.... i'm just wandeering is it possilbe to put two or more different materials on the same object...liek on one side of the cube there would be white paint and on the other side (othe plane of the same cube) there would be a brick or whatever? Link to comment Share on other sites More sharing options...
Tommy Burns Posted May 29, 2008 Share Posted May 29, 2008 Have a read up on Multi/sub object materials and then map channels for the uvw mapping. This is exactly what you need but it's not that easy at first. Link to comment Share on other sites More sharing options...
Logitek Posted May 29, 2008 Share Posted May 29, 2008 Hello Karolis, What you are looking for is a Material called "Multi/Sub-Object". Do a search in the Max help, it is pretty well explained on how to use it. Cheers, Link to comment Share on other sites More sharing options...
karolisbilz@yahoo.com Posted May 29, 2008 Author Share Posted May 29, 2008 thnx a lot.....i thought it was that....i was just hoping that there is a function like in CAD where u hold ctr key and mark the plane of the object that u want ur texture on.....but that was a bit naive ( hope i spelled it right lol) Link to comment Share on other sites More sharing options...
Logitek Posted May 29, 2008 Share Posted May 29, 2008 Actually, if you go in sub-object mode "Polygon", select one (or several) polygon, and apply a new material, it will automatically create a multi/sub-object material for you... But it is always good to understand how things work, so by doing it manually, at least you understand what's going on. Good luck with this. I agree this was kind of hard to understand at the begining, but I really don't know how I would work without this material! Cheers, Link to comment Share on other sites More sharing options...
