Eric Sosa Posted June 4, 2008 Share Posted June 4, 2008 [ATTACH]26971[/ATTACH] at this pace u will not make it block good luck anyways Link to comment Share on other sites More sharing options...
mmulv2 Posted June 4, 2008 Author Share Posted June 4, 2008 (edited) Dont worry, ur renders take 8 mins to render but the textures stuffed up, and i managed to get it to render at 10 mins with better textures. Any other way to cut down with the global switches? Edited June 4, 2008 by mmulv2 Link to comment Share on other sites More sharing options...
Eric Sosa Posted June 4, 2008 Share Posted June 4, 2008 try any, for exteriors, that comes along with the max program. go to: C:\Programs\Autodesk\3ds Max 9\maps\HDRs just remember to try different hdr angles & flips.... add the hdr to your mat editor,,any slot, then simply drag it to your "enviroment "reflection/refraction slot"....check it first to allow you to drag edit: google for hdr´s ...they are tens of them free in the net Link to comment Share on other sites More sharing options...
Eric Sosa Posted June 4, 2008 Share Posted June 4, 2008 Dont worry, ur renders take 8 mins to render but the textures stuffed up, and i managed to get it to render at 10 mins with better textures. Any other way to cut down with the global switches? try not to use "slow" vray mats....I saw the ones u did use and there are nice, but very slow..again, check the render speed when downlaoding vraymat from vraymaterials.de no way to cut on speed, if you want an ok render quality, after the setup u did receive from me unfortunatelly....you file is WAY too big for fast renders! Link to comment Share on other sites More sharing options...
mmulv2 Posted June 4, 2008 Author Share Posted June 4, 2008 Thnaks anyways. Im rendering atm at 550x431 with 180 frames and is taking 5 mins a frame which is very good. I turned of GI caustics as well (reflective and refractive) and increased the noise threshold from 0.001 to 0.01. It still looks quite good apart from the aluminium which is a bit noisy but expected and the cog doesnt look as good in previous renders but is probably good enough.. Is it ok if i post a few frames just to see your opinion once its done? Link to comment Share on other sites More sharing options...
mmulv2 Posted June 5, 2008 Author Share Posted June 5, 2008 I've uploaded the animation. http://rapidshare.com/files/120188661/animation.avi.html Tell me what ya reckon. Apart from the flickering and noise (which is a given since this threshold was increased to decrease rendering time), is it fine? Is there anyway to fix the flickering WITHOUT re rendering the animation? Thanks Link to comment Share on other sites More sharing options...
Joseph Petrino Posted June 5, 2008 Share Posted June 5, 2008 Wow. Rapidshare is really annoying. I gave up after 10 tries with the password. Sorry. Link to comment Share on other sites More sharing options...
Eric Sosa Posted June 5, 2008 Share Posted June 5, 2008 hehe...the rapidshare link doesn't work Mick couriose to see u't animation and give you my opinion. however...concider yourself lucky to make an animation of a one million polygones mesh in such short time Link to comment Share on other sites More sharing options...
mmulv2 Posted June 5, 2008 Author Share Posted June 5, 2008 Heres it again: http://www.2shared.com/file/3394371/24e6ba3a/animation.html The animation took around 16 hours all up which is pretty good for 190 frames. Tell me what ya reckon. The flickering kinds a ruins it but is good enough what i need it for. What do ya reckon of it? Link to comment Share on other sites More sharing options...
Joseph Petrino Posted June 6, 2008 Share Posted June 6, 2008 I haven't really been keeping up with this thread, but did you read this? http://www.spot3d.com/vray/help/150R1/tutorials_anim.htm The flickering is unacceptable IMHO. Keep trying. Link to comment Share on other sites More sharing options...
Eric Sosa Posted June 8, 2008 Share Posted June 8, 2008 I haven't really been keeping up with this thread, but did you read this? http://www.spot3d.com/vray/help/150R1/tutorials_anim.htm The flickering is unacceptable IMHO. Keep trying. indeed, lots of flickering, unfortunatelly Mick nice tip Joseph....never tried before however, the main problem is the size of the mechanic (polygone count) vs animation frame size and I beleive you did good Mick by making an animation out of that huge poligoned mechanical part, in such conditions there are several ways to correct the flickering of that animation, besides the tutorial solution, but any other would have taken years to animate. ....again, I hope you learn a bit more about max & vray mick...I did. NEVER TRY TO ANIMATE A ONE MILLION POLYGONE ESCENE UNLESS YOU GOT GREAT EQUIPMENT...AND THE RIGTH KNOWLEDGE! kind regards....Eric Link to comment Share on other sites More sharing options...
