mirjama Posted May 31, 2008 Share Posted May 31, 2008 Hi, I have a problem. I am new at vray, so please give me some advices. I have began to model a room, and at a beging I have stoped... This is a room just with a unfinished closet, till now, and there are some noise and dark lines at the ceiling and at a wall. It comes from yray lights which are placed at the windows. I tried everithing I knew, which is not to much:), but i can put them away only by excluding ceiling from vray lights. Is there other solution? And can you tell me will placement a glass panel at the window be a trouble for vray? I ask this becouse on one tutorial they didnt put a glass, just a vray light at a window. Thanks Link to comment Share on other sites More sharing options...
STRAT Posted May 31, 2008 Share Posted May 31, 2008 a picture says a thousand words Link to comment Share on other sites More sharing options...
tayrona Posted May 31, 2008 Share Posted May 31, 2008 hard to help without an image and some settings.... of course you can use glass in the window, a lot of people prefer to place light inside the room (leave a very small gap between glass and light)... light outside demands higher presets and render times Link to comment Share on other sites More sharing options...
mirjama Posted May 31, 2008 Author Share Posted May 31, 2008 You are right I have forgot1 Link to comment Share on other sites More sharing options...
STRAT Posted June 1, 2008 Share Posted June 1, 2008 first off remove all smoothing groups from the walls and ceilings. second, why not remove the window light and just use a regular vray light place outside further away? i personally steer clear from light portals as i find them slower, harder to control and just un natural. Link to comment Share on other sites More sharing options...
tayrona Posted June 3, 2008 Share Posted June 3, 2008 completely agree with strat... Link to comment Share on other sites More sharing options...
zeniamai Posted June 3, 2008 Share Posted June 3, 2008 You can also exclude the glass from your vray light. Link to comment Share on other sites More sharing options...
mayamax Posted June 3, 2008 Share Posted June 3, 2008 Hi I think You have To check This site...To see and Understand the Basic of vray and get your terms clear so you can play with them more easily. http://www.spot3d.com i hope this will help to you... Link to comment Share on other sites More sharing options...
mirjama Posted June 3, 2008 Author Share Posted June 3, 2008 Thank you a lott ! Link to comment Share on other sites More sharing options...
