djoshi Posted May 31, 2008 Share Posted May 31, 2008 How can we do the file linking especially .DWG in C4D. So that we do any modeling changes outside C4D, it gets updated in C4D without affecting textures..! Like we can do it in max with " File link manager".... OR any other way to update outside models..may be using some other file format ?? Link to comment Share on other sites More sharing options...
STRAT Posted May 31, 2008 Share Posted May 31, 2008 you cant. you can use xrefs (c4d to c4d files) but thats it. Link to comment Share on other sites More sharing options...
djoshi Posted May 31, 2008 Author Share Posted May 31, 2008 I am new to C4D.. there is no other way to do it..? " Xref " can it help.. ? how..? There are many people use different software for modeling & C4D for rendering how they do it?? Link to comment Share on other sites More sharing options...
STRAT Posted May 31, 2008 Share Posted May 31, 2008 xref is just using c4d files 'within' c4d files. i use different softwares for modeling and rendering - i use autocad and sketchup for modeling and c4d (with vray) for rendering. When my autocad model is complete, i make a .3DS file of it and bring it into c4d. if the model then requires to be changed, i make the changes of the appropriate bits in autocad and re-import those new bits into c4d. i just drag and drop the materials from the old bits onto the newly changed bits, then just delete the old. you cant 'live' mix formats in c4d. Link to comment Share on other sites More sharing options...
jackb602 Posted May 31, 2008 Share Posted May 31, 2008 Maxon does offer plugins for users of Vectorworks, ArchiCad and Allplan. They allow you to change the model externally, and then update the Cinema model while keeping materials intact. This link explains it a bit more: http://www.maxon.net/pages/products/editions/architecture/import_e.html You can't do this with AutoCad however, as Strat noted. I don't use the plugins myself (though Vectorworks looks tempting) so I use a workflow similar to Strat's, exporting from FormZ. Jack Link to comment Share on other sites More sharing options...
Wokka Posted June 3, 2008 Share Posted June 3, 2008 The live file linking work great (ay least with Archicad and Vectorworks). The updated model is just merged into C4D and automatically alters the objects changed without needing to reapply materials etc (depending upon the method you use). For AutoCad, could you have a dwg placed in a C4D file and Xref it into the model C4D file. If the DWG is updated, you only updated the 'xref'ed' file? That should not affect the main model file? Link to comment Share on other sites More sharing options...
Frosty Posted June 3, 2008 Share Posted June 3, 2008 I use FormZ as a modeler as well. Its quite quick once you know what you're doing. Link to comment Share on other sites More sharing options...
Alliance Posted October 16, 2008 Share Posted October 16, 2008 (edited) xref is just using c4d files 'within' c4d files. i use different softwares for modeling and rendering - i use autocad and sketchup for modeling and c4d (with vray) for rendering. When my autocad model is complete, i make a .3DS file of it and bring it into c4d. if the model then requires to be changed, i make the changes of the appropriate bits in autocad and re-import those new bits into c4d. i just drag and drop the materials from the old bits onto the newly changed bits, then just delete the old. you cant 'live' mix formats in c4d. How do u save a 3ds file in autocad ....i tried saving and also exporting but i cant get the option of 3ds in my options.It can be saved as a dwg and many other formats but no 3ds. Edited October 16, 2008 by Alliance Link to comment Share on other sites More sharing options...
STRAT Posted October 16, 2008 Share Posted October 16, 2008 Link to comment Share on other sites More sharing options...
Alliance Posted October 16, 2008 Share Posted October 16, 2008 You said " When my autocad model is complete, i make a .3DS file of it and bring it into c4d." and i thought that u could export the model from autocad as a 3ds ...sorry about that Link to comment Share on other sites More sharing options...
STRAT Posted October 16, 2008 Share Posted October 16, 2008 ah, (i see you've since edited your post. you asked how to export from C4D, not autocad ) in autocad, type in EXPORT. (although in the latest AutoCAD you cant save out as .3DS files (unless you have the secret plugin )) Link to comment Share on other sites More sharing options...
Alliance Posted October 16, 2008 Share Posted October 16, 2008 ah, (i see you've since edited your post. you asked how to export from C4D, not autocad ) in autocad, type in EXPORT. (although in the latest AutoCAD you cant save out as .3DS files (unless you have the secret plugin )) Which is? Link to comment Share on other sites More sharing options...
Andres del Castillo Posted October 16, 2008 Share Posted October 16, 2008 In acad 2008+ the export to 3ds option, doesn`t exist. You can save as dxf. The cinema 4d architecture edition allows you to import .dwg. Link to comment Share on other sites More sharing options...
Alliance Posted October 17, 2008 Share Posted October 17, 2008 Which is? So? Link to comment Share on other sites More sharing options...
