Josh1587140445 Posted March 6, 2003 Share Posted March 6, 2003 I am just curious on what size and resolution everyone typically renders at. I have pretty much stayed to 11x17 size at a 300dpi. But it I was to just the image up to say 24x36, would you reduce the dpi at all? Most of the stuff I do is for print. But it is for sit down meets. No big presentations yet. Link to comment Share on other sites More sharing options...
STRAT Posted March 6, 2003 Share Posted March 6, 2003 i generally render out at 2000x1500 px. this is pretty good for most sizes. This is quoted from Jeff Mottle in a previous post - Basically when you are printing/rendering an image you have three variables to consider: 1. DPI/PPI (Dots per Inch/Pixels per Inch) Both are the same thing and are also known as resolution. 2. Pixel size - measured in pixels (this is normally what you render to andiis how monitors are measured. 3. Print size - measured in inches (can be anythign but I'll use inches for convinience) 1. DPI/PPI First you need to know what resolution your printer can handle. Some will say that they go to 1200 dpi or 600 dpi, but in practice you should never need to go bigger than 300 dpi, even if you are printing a 60 ft wide billboard. Just like digital camera's non-optical zoom abilities, printers use DPI to claim superiority in the industry. DPI is the number of dots of ink that are put down by your printer onto a page over a one inch line. The amount of resolution that a printer can achive is based upon how close together the print head elements or jets are positioned. Of course it is a bit different with a 4 color press, but for now I'll just leave it at that. You may also notice that your inkjet will say that the vertical resolution will is different than the horizontal resolution. This is becuase in one axis the printer is relying on the proximity of the jets to each other, whereas the oher diection is related to the sensativaty of the rollers that are feeding the paper across the jets. 2. Pixel Size I'm assuming that everyone is pretty familiar with pixel size as we deal with is on a daily basis. However, don't assume that your print house will be, because in many case they are not. You will usually need to give them an image size in inches based upon the resolution that their printer is capable. Don't try to explain it to them becuase they just won't get it. Pixels are something that your monitor uses to describe the very small square dots (pixels) of light that are lit up by the guns of your CRT. (LCDs are different) Typically we say that a monitor is 72dpi. A pixel translated to a page is usually represented by many dots of ink depending upon the print resolution. 3. Print Size This one is pretty self explantory and is the image size on the page that your printer printed. So you know what each one is but how do they relate to one another? As I mentioned earlier there are thee variables in this equation. To get one you must have the other two, so here are the possibilites: For these examples let's assume that our printer is capable of 300dpi I am going to print an 8 x 10 image and my rendered pixel size is 3000 x 2400 You have Pixel Size and DPI and want image size: This is useful when you want to know how big an image will print on your page if you do not allow the printer to scale the image at print time. (ie scale to fit). =========================== Image Width = Pixel Width / DPI Image Width = 3000 pixels / 300DPI Image Width = 10 Inches Image Height = Pixel Height / DPI Image Height = 2400 pixel / 300 DPI Image Height = 8 Inches You have Pixel Size and Inches and want DPI This one is not all that useful and I can't think of any reason to use it practially but here is it anyway. ======================================== Horizontal DPI = Pixel Size (Width) / Inches (Width) Horz. DPI = 3000 pixels /10 inches Horz. DPI = 300DPI You can use the same equation for the Vertical DPI as well. Some printer are the same resolution in both axes. You have Inches and DPI need pixels This one is usful when you know that your printer can print 300dpi and you would like to print an image that is 8 x 10 and need to nkow how big to render your final image to do this. Of couse you could always render it bigger, but rendering time is precious so you never want to render more pixels that you have to. ======================================= Pixel Width = DPI x inches (Width) Pixel Width = 300 DPI x 10 inches Pixel Width = 3000 pixel wide Again the same formula can be used for pixel Height as well. So now you know what each variable is and how they relate to one another. The biggest hurdle I suspect is how they relate to one anotehr visually, but that will have to wait for my DPF document. Hopefully this helps some of you and does not confuse you even more. Even if you do not fully understand the why yet, you will at least have the formulas so you know how. Link to comment Share on other sites More sharing options...
nisus Posted March 6, 2003 Share Posted March 6, 2003 As our printer (the guy, not the machine) prints at 254dpi, so we make everything at that resolution at the required scale (minimum A3). It's big/large: A3 = 42cm x 29.7cm at 254dpi gives you 4200x2970 pixels rgds nisus Link to comment Share on other sites More sharing options...
STRAT Posted March 7, 2003 Share Posted March 7, 2003 nisus - i understand exactly where you comming from but hey, 4200x2970 for A3 printing? man, you must spend ur life waiting for renders to finish printing at A3 at 1/2 that pixel size would look almost identical! Link to comment Share on other sites More sharing options...
Pavel Roder Posted March 7, 2003 Share Posted March 7, 2003 As soon as you are not looking at it under lens-glass it LOOKS identical Link to comment Share on other sites More sharing options...
nisus Posted March 7, 2003 Share Posted March 7, 2003 As we devellop all our prints like photo's, this IS noticable... Why do you think we don't do GI, but stay close to max3.1 fake? ;-p rgds nisus Link to comment Share on other sites More sharing options...
Ed Posted March 7, 2003 Share Posted March 7, 2003 Years ago, before the color printing technologies we have today, the only way I could get a high quality print was to send to a service and have a negative made from the file and then have photos made from the negative. Their required file size was 5000 pixels wide. I have found this to be a fairly good guideline for rendering resolution to this day. My clients ask for all different sizes of prints, so even though it is overkill for a small print, you can still get a good large format print from the same file. In response to your other question, I have found that a minimum of 100 dpi will still produce a good large format print (24x36). The 5000 pixel image will usually work fine. Another consideration is to render as high as you need to bring out the details in your image. You will also find that an image rendered at a high resolution and reduced in size will be sharper than an image rendered at the same smaller resolution. Link to comment Share on other sites More sharing options...
STRAT Posted March 7, 2003 Share Posted March 7, 2003 Originally posted by Ed: You will also find that an image rendered at a high resolution and reduced in size will be sharper than an image rendered at the same smaller resolution. are you sure about that or just hypothosizing? sounds fine in theory, but i'd seriously doubt that statment. Link to comment Share on other sites More sharing options...
Ed Posted March 7, 2003 Share Posted March 7, 2003 I originally read about the concept of downsizing several years ago in some publications about animation. They suggested rendering at twice the desired frame size and downsizing by half to create animation with sharper detail. I tried it, and to me it did seem to be better. Even though I don't normally use it for animation projects because of time constraints, I do use it on print projects. Personally, I can see more detail in the images, and with today's fast processors, there isn't that big a hit on the final render time of a single image. Also if you plan to add plants or other detailed items in Photoshop afterwards, the higher resloution will allow finer detailing and control. Link to comment Share on other sites More sharing options...
John Dollus Posted March 7, 2003 Share Posted March 7, 2003 With animation, that technique is used to soften hard edges and improve on low quality render settings. For print, you are only interpolating pixels and creating blended edges with the reducing technique. I generally render out at 100% physical size and half the dpi resolution of the target printer. Then again, I print everything out on a Lambda anyway which makes pretty much everything look great. Link to comment Share on other sites More sharing options...
nisus Posted March 7, 2003 Share Posted March 7, 2003 I agree with Ed. When we do know we have to do a poster, we render even larger, but going from A3 to A0 is not too big a problem when properly rendered at a hi-res. We got this question all the time: lovely image (A3), will you make an A0 print to hang in our office? Really, try making an A0 poster from a less than 2000px image... So basicly we try to walk the best intermediate... Strat: working at highres and downscaling gives an extra soft interpolation and combined with a sharptool afterwards DOES gives more detail. (That is when scaling down per full pixel of course) The extra resolution makes masking a lot easier rgds nisus Link to comment Share on other sites More sharing options...
STRAT Posted March 8, 2003 Share Posted March 8, 2003 Ed and nisus - if thats what ur saying then i'll have to give it a bash. thanks for the tip then Link to comment Share on other sites More sharing options...
nisus Posted March 8, 2003 Share Posted March 8, 2003 Hi strat, I'll try to explain what happens, so you can understand things a bit, because I couldn't believe it at first myself either. Start Autocad, draw a 100 by 100 rectangle. Copy this rectangle and rotate it about 10degrees. Export both rectangles to a monochroom eps. Next import this eps into ps at a a size of about 200x200pixels. Check the file at 100% next at 500%. You will see a steplike affect (aliasing). Next import the same eps at 1000x1000pixels, rescale to 20% of the original size and check the file at 100% and 500%. It looks smoother (anti-aliasing) So what is happening??? In the first file, the eps gets imported and uses black or white only. In the second file, the same happens (black and white only) but by scaling down the image extra graylevels are used during the interpolation. These graylevels give the image a smoother (anti-aliased) effect... rgds nisus Link to comment Share on other sites More sharing options...
