Nvidia GeForce to Quadro Soft-Mod ...Gelato GPU rendering
Hi
The topic about Nvidia GeForce to Quadro Soft-Mod was debated a bit on this forum, but I think some important things escaped at the first look.
http://www.techarp.com/showarticle.aspx?artno=539&pgno=0
The most important thing is the announcement from Nvidia that Gelato Pro is free for download. Gelato is a powerful GPU rendering system for Max/Maya with advanced capabilities.
http://www.nvidia.com/page/gz_home.html
The light version can be used with any GeForce (from 5200) but the Pro version can be used only with QuadroFX. The difference between them: interactive relighting, multithreading, network rendering, 64 bit support….. just a few of them
The best things to come….. MentalRay was aquired by Nvidia
I think this topic deserves a lot of attention if you`re thinking from a future perspective
Best regards.
Mihai
Have you seen anything on whether it works with a soft-mod card? Cause there are still some limitations on those. Also, I guess the situation would improve if they integrated mental ray into this, but so far I haven't seen anything that makes me believe Gelato is good enough to go against mr/Vray/etc. in architectural rendering...
I`m thinking at Gelato from the speed/quality ratio point of view…. fast renderings with decent look. Behind Amaretto (the plugin for 3DS Max) is FranticFilms http://www.franticfilms.com/software/products/amaretto/overview/
Some projects from FranticFilms:
http://www.franticfilms.com/vfx/
http://www.franticfilms.com/vfx/projects/archive/
and a bit about their software:
http://www.franticfilms.com/software/products/overview/
Edited by vizfx
I wonder how many years we will have to wait before nvidia allow mental ray (seeing as they've owned them for a while now) to execute on gpu's as well as cpu's. It sure would change the spec of your average render node. Triple SLI anyone?
Video Card: 7900GTO MAX2008
Display Type:
File Name | FPS
4viewports.MAX | 57.6701
8direct.MAX | 456.621
8omni.MAX | 387.597
8spot.MAX | 328.407
blitting.MAX | 834.724
dualplanes.MAX | 862.999
geometry1.MAX | 349.243
geometry2.MAX | 223.38
multitex.MAX | 1.1782
rasterize.MAX | 653.168
textured1.MAX | 465.839
textured2.MAX | 169.563
textured3.MAX | 169.319
transpar.MAX | 219.106
wireframe1.MAX | 16.5517
wireframe2.MAX | 15.9464
Comp High: 147.564
Comp Low: 148.2
Video Card: 7900GTO>Quadro 3500 MAX2008 1280/960
Display Type:
File Name | FPS
4viewports.MAX | 87.6424
8direct.MAX | 512.821
8omni.MAX | 400.0
8spot.MAX | 337.268
blitting.MAX | 969.619
dualplanes.MAX | 908.747
geometry1.MAX | 392.157
geometry2.MAX | 236.967
multitex.MAX | 1.17777
rasterize.MAX | 435.35
textured1.MAX | 494.723
textured2.MAX | 171.821
textured3.MAX | 170.184
transpar.MAX | 225.428
wireframe1.MAX | 81.3449
wireframe2.MAX | 45.6066
Comp High: 199.446
Comp Low: 172.065
the mode is not perfect I know but who cares!
egz > you can not install MAXtreme, fuinny thing isnt it?
BUT I can install quadro driver and 3dsMAX works like a beast. ALMOST, NO crashing at all. Ofcourse the group helpe is still problem for MAX viewport
An interesting point of view on my post at Nvidia forums:
"I have been able to access all the pro features using all of my NVIDIA Geforce enabled machines, so there is essentially no benefit for anyone to 'emulate' a Quadro any more.
Comparing MentalRay and Gelato is not comparing apples with apples. MentalRay is not an accepted standard when dealing with film. It is a boutique product and seems to be more popular with architects, industrial designers and so on. One would assume that this is where most of NVIDIA's Quadro boards end up as well. Some 3D artists may use MentalRay in film, but it is definitely not the norm. The shading language is different, and more people know the Renderman shading language than do the MentalRay equivalent. It's a financial no-brainer for NVIDIA to move into MentalRay and push for it's use in the design/engineering industry. Don't expect a free version any time soon, as it seems like another Quadro selling exercise.
At least Gelato was more closely aligned with the accepted film practise of using Renderman based renderers and had a better chance of making it in to the film industry.
As for the quality issue, it comes down to the 'look' of MentalRay, 'out of the box' that makes it seem better qulaity. You need to play with more settings and put more work into shading and lighting before Gelato starts to look sexy. Classic case of garbage in garbage out."
