Ky Lane Posted June 6, 2008 Share Posted June 6, 2008 SoftQuadro... Anyone done it before? Worth it on a 8800GT? Would like any suggestions. Link to comment Share on other sites More sharing options...
AJLynn Posted June 6, 2008 Share Posted June 6, 2008 You might as well try but from Joel's experience here it might not be possible to mod the 8800GT with the current tools. I did the 8800GTS to FX4600 mod and the 8600GT to FX1700 and got some good results. Link to comment Share on other sites More sharing options...
Ky Lane Posted June 6, 2008 Author Share Posted June 6, 2008 Darn, thats sucks Was getting all excited too! Link to comment Share on other sites More sharing options...
Macer Posted June 6, 2008 Share Posted June 6, 2008 Its a bit more difficult with vista 64 too. Since the last service pack, disabling verified drivers is more difficult? Still looking for an easy solution. Link to comment Share on other sites More sharing options...
AJLynn Posted June 6, 2008 Share Posted June 6, 2008 This is in Vista64? I've only tried it in XP32. But, why talk about it when you can try and see if it works? Link to comment Share on other sites More sharing options...
Antisthenes Posted June 9, 2008 Share Posted June 9, 2008 unless you are a gamer i see no reason not to Link to comment Share on other sites More sharing options...
Ky Lane Posted June 10, 2008 Author Share Posted June 10, 2008 After ALOT of research, i found out the 8800 series cards are hardware locked, and cant be softquadro'd... how disappointing! Link to comment Share on other sites More sharing options...
AJLynn Posted June 10, 2008 Share Posted June 10, 2008 Not entirely true - I already did an 8800GTS and it worked. It's also supposed to work on the GTX. GT is a different, newer core, so maybe it doesn't work. My 8800GTS (AKA FX4600) and my coworker's 8600GT (FX1700) are performing a fair bit better in OpenGL than before. Since we all thought it didn't work on the 8800GTS (NV84 core), then they came up with a workaround, I'm assuming the GT (NV92) will get one eventually. That NV92 is similar to what's in an FX3700. Link to comment Share on other sites More sharing options...
Ky Lane Posted June 10, 2008 Author Share Posted June 10, 2008 AJLynn said: Not entirely true - I already did an 8800GTS and it worked. It's also supposed to work on the GTX. GT is a different, newer core, so maybe it doesn't work. My 8800GTS (AKA FX4600) and my coworker's 8600GT (FX1700) are performing a fair bit better in OpenGL than before. Since we all thought it didn't work on the 8800GTS (NV84 core), then they came up with a workaround, I'm assuming the GT (NV92) will get one eventually. That NV92 is similar to what's in an FX3700. Thats correct - its using the G92 core, which is apparently blocked.. hopefully someone comes up with someothing to get around it. Link to comment Share on other sites More sharing options...
