Camby1298 Posted June 16, 2008 Share Posted June 16, 2008 Anybody know of a script out there that can control exposure control per camera and not in a general sense. Much like the camera work flow in Vray...its makes more sense this way when you have multiple cameras in a scene ranging from interiors to exteriors. What was Mental Images/Autodesk thinking??? Link to comment Share on other sites More sharing options...
odouble Posted June 16, 2008 Share Posted June 16, 2008 How about using scene states to manage your environment settings Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 16, 2008 Share Posted June 16, 2008 you could try this, which may make it a little easier, though i have not messed around with it myself. you would simply set different exposures, and save them to a material library. then you would replace the lens shader per view you are rendering. it would still be a two step process. http://www.germanmentalray.de/viewtopic.php?t=1041&highlight=boexposurephotographic what they need to do is set the exposure up as a modifier that is applied to the camera, much like the lens correction. then you could have per camera exposure. Link to comment Share on other sites More sharing options...
