dimmubodom84 Posted June 17, 2008 Share Posted June 17, 2008 !Im trying to do a roof for an apartment complex, the overhang in some parts are different. I have attached a file that shows the Roof in Plan view but now I need to make it 3d. I was trying to use the Tool Palette ROOF TOOL. can some one please help I can't miss my deadline! please!!! Im using AutoCAD Architecture 2009 Link to comment Share on other sites More sharing options...
litleboy Posted June 17, 2008 Share Posted June 17, 2008 if all the edges are at the same level, you shouldn't have a problem use the roof tool, select the correct pitch and just follow the edges.. I found that most of the designers/architects that send me complex pitched roofs are wrong. so it could be that the line projections ans brake sin the roof are wrong. Link to comment Share on other sites More sharing options...
dimmubodom84 Posted June 17, 2008 Author Share Posted June 17, 2008 if all the edges are at the same level, you shouldn't have a problem use the roof tool, select the correct pitch and just follow the edges.. I found that most of the designers/architects that send me complex pitched roofs are wrong. so it could be that the line projections ans brake sin the roof are wrong. thanks litleboy for the reply. All the Edges are the same level, but still not coming out correct. Is there anyway you can walk me throught the steps please. Link to comment Share on other sites More sharing options...
litleboy Posted June 17, 2008 Share Posted June 17, 2008 select the roof tool, and its just liek drawing a close polylline around the building edge.. you can adjust later the pitch and overhangs, Link to comment Share on other sites More sharing options...
