whori Posted June 18, 2008 Share Posted June 18, 2008 Hi everybody I see that 3ds max material editor got only 24 slots...is it possible to increase this number? If I got scene with a lot of element that need different material, and i dont want to use multi/sub-Object material... is there are any other way? Thank you Link to comment Share on other sites More sharing options...
kippu Posted June 18, 2008 Share Posted June 18, 2008 the 24 materials is not a limitation on your scene ..you can only view 24 materials at a time ...other than that you can use how many number of materials you need ... Link to comment Share on other sites More sharing options...
whori Posted June 18, 2008 Author Share Posted June 18, 2008 the 24 materials is not a limitation on your scene ..you can only view 24 materials at a time ...other than that you can use how many number of materials you need ... I just need to use different names for materials? am i right? and if i want to change it.. how it is done? yes its stupid question, but i never did this before:) i mean using a lot of materials Link to comment Share on other sites More sharing options...
dean@pikcells Posted June 18, 2008 Share Posted June 18, 2008 the big search button at the top of this page will probably give you hundreds of topics with the same question and answers. failing that, theres always the max help files (F1 by the way) Link to comment Share on other sites More sharing options...
whitetr Posted June 18, 2008 Share Posted June 18, 2008 Hi, When I work with materials, I only use the 2X3 grid...it's my bad eyesight:) Anyway, when I'm finished with any particular material, I'll drag a "blank" material from an unused slot over a material I'm done with. It doesn't affect the scene, just the material editor. Also, I'll use the "Utilities->Reset Material Editor Slots" to get a clean editor. If you need to recall any materials from the scene, you can use the eye dropper tool and select striaght from the viewport or use the "get material" dialogue and click "scene" in the browse from section. Link to comment Share on other sites More sharing options...
whori Posted June 18, 2008 Author Share Posted June 18, 2008 Hi, When I work with materials, I only use the 2X3 grid...it's my bad eyesight:) Anyway, when I'm finished with any particular material, I'll drag a "blank" material from an unused slot over a material I'm done with. It doesn't affect the scene, just the material editor. Also, I'll use the "Utilities->Reset Material Editor Slots" to get a clean editor. If you need to recall any materials from the scene, you can use the eye dropper tool and select striaght from the viewport or use the "get material" dialogue and click "scene" in the browse from section. heh thanks a lot Link to comment Share on other sites More sharing options...
