craigball Posted June 18, 2008 Share Posted June 18, 2008 I have just got my new pc and more or less every time I open max or photo shop the two screens flicker whan its loading up. It driving me mad. Any one able to help me fix it? The graphics card I am running is nvidia quadro fx 1700. Link to comment Share on other sites More sharing options...
Slinger Posted June 18, 2008 Share Posted June 18, 2008 What drivers are you running? Did you buy the PC from a manufacturer or build it yourself? Link to comment Share on other sites More sharing options...
Lester_Masterson Posted June 19, 2008 Share Posted June 19, 2008 Check the following if is applies: Make sure you are using shielded speakers Make sure your battery back up/external hard drive/USB powered coffee maker, is nowhere near the monitor If using DVI converter dongles, make sure it is not the culprit. A defective one drove me nuts with my old FX1100. Are they CRT's? If so, check to make sure the refresh rate is set to the highest (ie: 85hz or above) If they are LCD's, make sure the refresh rates are set to the manufacturer's suggested setting. Make sure you are using the recommended resolution as well. Hope this helps. Link to comment Share on other sites More sharing options...
craigball Posted June 19, 2008 Author Share Posted June 19, 2008 What drivers are you running? Did you buy the PC from a manufacturer or build it yourself? i dont no what you mean by drivers sorry but it was a custom built system from the manufacturer. Link to comment Share on other sites More sharing options...
Slinger Posted June 19, 2008 Share Posted June 19, 2008 go download gpu-z. Run the app. near the bottom it will tell you the driver version you are running. I want to make sure you have the newest driver out there. BTW, what graphics card are you running? Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted June 19, 2008 Share Posted June 19, 2008 our newer ones with the 1700 were doing the same with the supplies drivers, i believe we just updated them to the latest from the nvidia website and that went away. (Along with fixing some issues we were having with various video codecs) Link to comment Share on other sites More sharing options...
craigball Posted June 20, 2008 Author Share Posted June 20, 2008 thanks evey one i fixed the problem by Uninstalling my old graphics drivers and installing the latest ones of the nvidia web site. BOOM all sorted happy days all round!!!!! Link to comment Share on other sites More sharing options...
