3dway Posted June 19, 2008 Share Posted June 19, 2008 We use a half circle for our level elevations. We flip this when two are close and conflict on the drawings. We're just starting with Revit, and I've made a custom level head buble but I would like to be able to put flip control on it. It's not available at the side as a tool when editing the level head family. Can anyone help? Thanks, Link to comment Share on other sites More sharing options...
Richard McCarthy Posted June 26, 2008 Share Posted June 26, 2008 I don't think Level head can have flip control on it. The way around it is to use parametric visiblity function to toggle it. eg. Set up two sets of level head however you want it, select the first group > element property > graphics tab > visibility , then the button besides visibility (square button)> add parameter. Call it "Up" level head (or whatever you want), and do the same for the other group except name it "down" level head. Save the Family as family parameter as oppose to Shared parameter. Now once you start using the new level head, you can goto level head's element property menu, edit > and then select either up or down. Link to comment Share on other sites More sharing options...
