more than 2 maps in the checker slots
lyca
Hi
i want to do a tiled texture where i have 5 variations of the same square, if i use the checker i can put 2 maps in the diffuse channel,
is there a way use more maps than 2 maps in the diffuse channel ?
Yes. You could use Tile maps with no grout (0) and high Fade Variance. Use the tile to mix between the maps and add more levels as you need.
Check the file(mat lib). This would work for four different maps. That's where the levels of mixing come to play.
