Antisthenes Posted June 20, 2008 Share Posted June 20, 2008 very useful for announcements if you don't follow the newsgroup http://blog.rhino3d.com/ Link to comment Share on other sites More sharing options...
Fran Posted June 20, 2008 Share Posted June 20, 2008 Thanks for the heads up Jonas. Link to comment Share on other sites More sharing options...
Fran Posted June 20, 2008 Share Posted June 20, 2008 This edge softening plugin is way cool! I wouldn't have known about it except that Bob blogged about it yesterday. http://en.wiki.mcneel.com/default.aspx/McNeel/EdgeSoftening.html It works with fryrender and any other RDK-compliant render engine. When you install the plugin, Edge Softening becomes an object property that you can enable and set parameters. This is a very (very, very) quick render I did with fryrender: Link to comment Share on other sites More sharing options...
Antisthenes Posted June 21, 2008 Author Share Posted June 21, 2008 yes it makes a great difference how did you get fryrender to work i am still getting DLL errors trying to load the demo, witch RDK do you have to make it go? Link to comment Share on other sites More sharing options...
Fran Posted June 21, 2008 Share Posted June 21, 2008 Hi Jonas, You use the latest RDK that is available from McNeel. If you are running xp64, you still need to download and install the 32-bit version of the demo and install that first. Then install the 64-bit version. I only mention this because I was having dll errors until I did that. BTW, the Curve Piping plugin is very cool too, and also works with fryrender (and any other RDK-compliant renderer). It's like having renderable splines (ala 3ds Max). To demonstrate, I very quickly created a box and extracted the wireframe, then set the curve piping object property to .5. I think it is actually much nicer than the Max equivalent. Link to comment Share on other sites More sharing options...
