if ur familiar with Chris Nichols Method ?
fadi3d
guys i was experimenting with Chris Nichols Method (the one in Speed Vs Quality) and i was wondering if for first bounce we have to use Brute Force or Irr ? and if Brute Force Does the the Subdiv Matter ? as he sets tthe Adap Amount to 1. instead of 0.85
and guys is the Lanczos or Sync filter Very Different ?and How?
The comment is made in the tutorial that he is typically is working with animated scenes which is why he defaults to using a brute force method. If you aren't animating Irr Map is still the way to go IMO.
As for the AA filtering types check out the bottom of this page from the following link, it explains the filters types and their application.
http://www.spot3d.com/vray/help/150SP1/examples_image_sampler.htm
edit: I just realized Lanczos isn't on that page.... so a couple links posted by chris on chao's forums might give you some better answers....
  cpnichols said:
And yes.... Lanczos is my filter of choice, if I need anything sharper I'll do it in post.
Edited by BrianKitts
chris thanks for the link man altough it seems they don't mention th Lanczos Filter.Still i got another question for u man (or any one that might jump in) i don't know if u read my last Thread (Any vray Wizard ?)but if ur familiar with this method Chris states that almost all of the time he settles for Dmc 1-16 and Clr 0.01 and sometimes he goes for 1-25 and Clr 0.005.
my Question is :is it exact sience (ie the relation between the Dmc numbers and the Clr Thresh or we have to do some testing ?
thank u For ur time it's always a pleasure Communicating with u guys .
additional info...
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=37212
  Vlado said:
The sinc filter is a sharpening filter, while the lanczos one is a smoothing filter. They are neither particularly faster nor slower than the standard filters, but may look somewhat better (although this is very subjective).
Best regards,
Vlado
if you are not doing an animation, and speed is the issue, i would recommend experimenting with no AA filter. you can do a good job controlling the AA in the image through the sampling parameters, then adjust in post as Brian noted to suite your taste.
