Ruprect Posted June 22, 2008 Share Posted June 22, 2008 Hi there, If I had any hair left, I would have pulled it out over this project. It seems the more work I do on it the worse my results are becoming. I would really appreciate advice and crits on this one. My setup is using Vray lightcache, and a dome with vraylight mtl and an additional vray light. Link to comment Share on other sites More sharing options...
STRAT Posted June 23, 2008 Share Posted June 23, 2008 can you tell me where i can buy a pair of those anti-grav shoes they're all wearing? Link to comment Share on other sites More sharing options...
Dave Buckley Posted June 23, 2008 Share Posted June 23, 2008 www.anti-gravity-shoes.com hahaha good spot, made me chuckle Link to comment Share on other sites More sharing options...
Ruprect Posted June 23, 2008 Author Share Posted June 23, 2008 Ooops.. Link to comment Share on other sites More sharing options...
Ian P Posted June 23, 2008 Share Posted June 23, 2008 I wouldnt use light cache on an external, i think thats partly why your getting such wierd results you'll get better results on an exterior with brute force but you may have to brighten the image to compenstate. Link to comment Share on other sites More sharing options...
Ruprect Posted June 23, 2008 Author Share Posted June 23, 2008 Thanks Ian, I will give that a go. Link to comment Share on other sites More sharing options...
Horhe Posted June 23, 2008 Share Posted June 23, 2008 can you tell me where i can buy a pair of those anti-grav shoes they're all wearing? The question is not where but how.... Link to comment Share on other sites More sharing options...
Tedrux Posted June 23, 2008 Share Posted June 23, 2008 Hi, The geometry is ok, it just looks a little flat. I don't use Vray because I'm skint and can't afford it so i use mental ray. There must be some settings in Vray that let you boost samples to get more occlusion... I use area lights to get really nice shadows with soft edges. Some of the maps have visible tiling and the bump maps don't really work. You should invest in some professional materials or create some good ones yourself including masks and overlays to get shut of the tiling. Sorry for the hammering, I'm no expert but I beleive in honest critisism! One more thing; you missed some vital elements to make it look more convicing: Rain water pipes!... they make the diffrence on flat walls. Cheers, Ted (Andrew Holt) Link to comment Share on other sites More sharing options...
Ruprect Posted June 23, 2008 Author Share Posted June 23, 2008 Thanks for the advice Ted.. Your spot on about the drain pipes, and I see that some work could be done on the textures. And don't worry about the hammering, I put these images up for critisism so that I can take on board the advice and become a better artist. Link to comment Share on other sites More sharing options...
Richard McWilliams Posted June 23, 2008 Share Posted June 23, 2008 Adding control joints in your stucco will help a lot for detail. Also the red leaves seem too big for the scale. Good luck! Link to comment Share on other sites More sharing options...
Ruprect Posted June 23, 2008 Author Share Posted June 23, 2008 I downloaded the Solid Rocks Vray assist demo, and did a quick render using pretty much the default options.. Here is the result. Oh yeah..and I took away their anti grav boots!! Link to comment Share on other sites More sharing options...
Ruprect Posted June 23, 2008 Author Share Posted June 23, 2008 Thanks for the advice Richard... Control joints in Stucco and leaf size added to the list. Link to comment Share on other sites More sharing options...
