export dwg from max to autocad,problem
niko3d
Hello,
I would like to ask a question.
I have a problem with exporting a DWG file from max to autocad.
When i'm exporting the file to autocad, the objects are polylines. Is there a way to export the file and have the objects in autocad seen as solids?
Im using the latest versions of both programs.
Thank you
athens, belgium ?
anyways, the short (5:45 am) answer is no, but if you are able to export as polylines, then it is very simple to extrude those into solids in autocad using extrude (EXT) or even press-pull.
or are your 3D shapes quite complex, and not simple extrusions ?
