ravi_chawda1981 Posted June 27, 2008 Share Posted June 27, 2008 please help! I m doing a walkthrough. I am using Irraidance map as prmry and Light Cache as secondary engine! I ve given path for saving Irraidance map under multiframe incremental and Light cache under fly through mode! My problem is, while calculating the Irrdnce and Light ache map it is first calculating the last frame in Building light cache and then calculating the first frame in prepass. after calcuating for nearly 3 hrs the final rendering is not proper. Please help me out! Link to comment Share on other sites More sharing options...
Saj Posted June 27, 2008 Share Posted June 27, 2008 Hi. do it seperately? put light cache for both primary and secondary, set to flythru and render and save (check don't render final image) then do the same for the Irr map, only this time, render every 'n'th frame, depending on the speed of ur camera. I hope that solves the problem, but m not too sure :S Link to comment Share on other sites More sharing options...
ravi_chawda1981 Posted June 28, 2008 Author Share Posted June 28, 2008 Hi. do it seperately? put light cache for both primary and secondary, set to flythru and render and save (check don't render final image) then do the same for the Irr map, only this time, render every 'n'th frame, depending on the speed of ur camera. I hope that solves the problem, but m not too sure :S thnx for replying i ve done as u said but still not worked properly then i change the renderer and come back to vary(refresh the renderer) and this time it clicks! the map load properly! any ways thnx a lot for your kind cooperation! Link to comment Share on other sites More sharing options...
STRAT Posted June 28, 2008 Share Posted June 28, 2008 i use vray for c4d. does anyone here use both and can compair the similarities? only i've written a couple of gi animation tutorials for it that will instantly solve all your problems. Link to comment Share on other sites More sharing options...
