Jitter problem
rakeshtagotra
we cant analise what the jitter is unless we see it in the animation, and if you're not going to post it we cant see it, and your description isn't good enough as there could be numerous jitter causes.
Ok
>>>do one thing, select the multiframe mode in irradiance map, click all the blanks below and save irradiance map through Browse button(Assign Path).
>>>click the 'dont render the final image' blank in global swithes.
>>>then come to common parameters give the range of your animation and mentioned the interval of frames in 'every nth frame category'.
tht will solve your problem.:)
its crashing because you dont understand the settings...and those irrmap settings are the most weirdest i have ever seen... some are high , some are low ...i mean why do you adaptive amount as 0.708? the default works.. and global multiplier at 4.5 ? are you having that much noise that you are upping samples to smooth it ...
but if you need help on jitter . i suggest you use LC for your secondary bounce and work it from there...
and dont use detail enhancement for animations too
