david.jones Posted July 1, 2008 Share Posted July 1, 2008 Ok, i do all my animations in Pal frame rates, 25 fps. But my library of bip motions are all in NTSC frame rates, 29.9fps This is fine, they still import and convert key frames ok. But, every so often i get a scene with animated bipeds, that always open with the question keys dont match the frame rate, do you want to map or quantize. Selecting and saving doesnt stop this question the next time, I try to resave all bip files, and then reload them etc, this doesnt always solve it. Should i always merge bips through the import motion capture method? I cannot find a definative solution to this, anyone get the same problem, or know a good, quick solution?? Cheers. Link to comment Share on other sites More sharing options...
