Dem/Topography question
So, in the past I've used the usgs national map viewer to extract 3d topography in GeoTiff format, which i then converted via 3dem to DEM format, which i then imported into max with some free plugin I'd found online.. a bit of an evil process to say the least.
Now, i need to dig me up some topo for the LA valley and was wondering if there is any other good/reccommended ways to get it nowadays that doesn't involve a java interface from 2001 and many hours of work? ;)
Dave,
I get elevation data from this site: http://data.geocomm.com/catalog/US/61057/431/group4-3.html
You can download the data for free using the green download arrows.
There's a free program called sdts2dem.exe. Use that to create the DEM file. (just copy sdts2dem.exe into the folder with the elevation files and run it)
I then use polytrans (not free) to import the DEM data, export to a 3ds, and import into max.
I think you can also import the DEM data directly to max, but it is a super heavy mesh. Polytrans does a much better job of interpolating the data into a usable mesh.
If anyone has a better/faster method than that I'd also like to know about it :)
Hope that helps,
Probably beats the current workflow of making terrain, and draping a cloth sim on it to get a decent quad mesh to begin editing on lol.
Just curious, why does it even matter if the final terrain mesh is composed of quads?
I regularly create large terrain models with only the road surfaces using quads for texture placement. Everything else is sweet clean triangles!
If anyone has a better/faster method than that I'd also like to know about it.
I was able to download a portion of that terrain and use the executable to get it into Max. You're right about it being a huge mesh.
I was also able to import the DEM file into AutoCAD using EasySite. ES has a routine that will create new contour lines from a set of faces and I can tell it the height interval. I can now triangulate these contours and build a terrain mesh with much lighter density wherever I need it.
Furthermore, ES gives great control for integrating the rest of the modeled infrastructure (roads, parking lots, building pads, etc.).
It doesn't really, its more for areas where i have to do heavy editing, we tend to get existing condition topography lines of dubious quality from civil guys, but are in early enough phases that we are grading/modifying the site ourselves
boy do they need a real website though
In short, an understatement, but don't judge a book by it's cover...:o
It is a solid tool with extremely useful features for large-scale terrain modeling.
I have been using it for nearly 3 years now on all of my rendering and animation projects. Big/small and everything in between...
