nelpiper Posted July 3, 2008 Share Posted July 3, 2008 (edited) Hig guys. I'm using MAX 8(not 2008) with vray 1.5 rc3. I'm doing a scene where a have a polygon with five differente materials applied to it so I have to use map channels to have the UVs laid out. The problem is that when I set the UVW map channel to other than CHANNEL 1 and match the material map channel with the same number, the texture in the material editor disapears, leaving only the base color. However, they show fine in the viewport. I know this is a vray problem because I've tested the same scene with SCANLINE and MENTAL RAY and materials are fine. Has anyone come across this problem before? Would that be a buf that has been sort out in later versions of vray? Thanks (wow, that was long!). Edited July 3, 2008 by nelpiper Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted July 4, 2008 Share Posted July 4, 2008 maybe this http://www.dizajnzona.com/forums/index.php?showtopic=50570&st=0&p=616483entry616483 look at the printscreen image Link to comment Share on other sites More sharing options...
nelpiper Posted July 4, 2008 Author Share Posted July 4, 2008 No it's not that. Thanks anyway. Link to comment Share on other sites More sharing options...
Thablanch Posted July 8, 2008 Share Posted July 8, 2008 Do not think it is a 1.5 rc3 (or 4) problem. For as long as I remember, Vray always done this. But it will render correctly. Link to comment Share on other sites More sharing options...
