richwebgfx Posted July 3, 2008 Share Posted July 3, 2008 (edited) I need to buy a quadro card which will be suitable for navigating my way around a large 3d model of a buisness centre and then for a fly through of the complex of one of the floors. The floor will be populated with the usual tables, chairs, items etc. The model will be given to us so i have no idea on poly count ATM, also bearing in mind when i populate the floors this will also put more of a strain on the card and it needs to be as smooth as poss when previewing the fly-through before i render it. I know this might be a difficult question to answer but if anyone has any experience with this type of project - as a rough ballpoint would a quadro 3700 be up to the job? Thank you!! http://la.gg/v/city1.jpg http://la.gg/v/city2_1.jpg http://la.gg/v/city3.jpg Rich. Edited July 3, 2008 by richwebgfx Link to comment Share on other sites More sharing options...
deadfly Posted July 3, 2008 Share Posted July 3, 2008 I'm currently using a 3700. Its great, but I can promise you it will cruise around smoothly. I recently worked on a car showroom, which featured 30 or so high poly cars. The card did keep up well in a wireframe view. Hope this helps. Link to comment Share on other sites More sharing options...
richwebgfx Posted July 3, 2008 Author Share Posted July 3, 2008 Thanks, So I'm assuming you couldn't use this card with textures showing in the viewport as well, only wireframe. Is it the amount of ram which is the limiting factor? Link to comment Share on other sites More sharing options...
AJLynn Posted July 3, 2008 Share Posted July 3, 2008 Your models there aren't actually that high poly - a room full of 30 high poly cars would be much more difficult for a card. With the models in your renders, I think they're run comfortably on my 8800GTS (with or without my Softquadro hack) or my FireGL v5200, and on my laptop with a Radeon x1600 it wouldn't be great but I'd make do. What software are you using anyway? Link to comment Share on other sites More sharing options...
richwebgfx Posted July 3, 2008 Author Share Posted July 3, 2008 I'm running studio max. I'm just a little worried that when i place all the objects to populate one of the floors if the card can handle a comfortable fly through in the viewport. Link to comment Share on other sites More sharing options...
AJLynn Posted July 3, 2008 Share Posted July 3, 2008 So put the stuff you're not looking at in box mode, or use Xrefs that can be loaded and unloaded by floor. Use proxies and instances. You'll need to do that stuff anyway when rendering the animation if it's high poly enough that a Quadro 3700 can't handle it. Link to comment Share on other sites More sharing options...
