cferman Posted July 3, 2008 Share Posted July 3, 2008 has anyone tried utilizing surfaces from civil 3d yet? When I import the xml file it gives me a mesh that I can't edit. And it also is not viewable in wireframe?? Link to comment Share on other sites More sharing options...
cferman Posted July 8, 2008 Author Share Posted July 8, 2008 baker1444 said: I only did this once but I just used file link manager in Max to attach the dwg file. Give it a go. When you did this were you utilizing a graded surface created from civil 3d or just linework? Link to comment Share on other sites More sharing options...
Astriti Posted May 8, 2009 Share Posted May 8, 2009 HI, I used one trick once.... here it goes I imported Landxml into 3ds max design 2009 then I created a plane aproximately to my terrain size a placed little bit higher than land xml in z-direction than I used Create (panel)-Compound object-CONFORM comand button than I projected this plane into my existing Landxml (it takes some minutes for max to do this) and at last I delete my landxml and I have my editaple poly terrain and I can manipulat more easily and teselate it... and other stuff... *Note: more numbe of segments your plane, more accurate your projection would be* any question on this tip please emaile to me at astrit979@hotmail.com cheers Link to comment Share on other sites More sharing options...
