res V's quality settings
STRAT
Hi guys
what's the general correlation/ratio between quality settings and resolution size? i mean, the higher resolution you render the settings can be different than for lower res.
how does this work and what kind of settings are we talking? i use vray for c4d and want to test the similarities.
thank you
maybe this will help.... not sure how accurate it is.
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=37760&highlight=resolution
  CCS said:
You reduce the values by 1 for every doubling.
So, 1000px wide to 2000px wide goes from -4 -1 to -5 -2
Then 2000 to 4000 goes to -6 -3
This is in keeping with the old IR precalc method anyway.
if you are rendering above 4000 pixels, i would probably just render a irradiance pass, and save it for reuse to keep the guess work out of it.
