sky portal
sardesign
Just make sure that Mental Ray is set as your render engine. The MR specific stuff won't turn up if it's not selected. Other than that, use my generic Everything-is-a-nail-and-the-only-tool-I-have-is-a-hammer fix:
weird problems with the interface??
Blow away (or rename) 3dsmax.ini
C:\Documents and Settings\[uSERNAME]\Local Settings\Application Data\Autodesk\3dsmax\9 - 32bit\enu
Man, I should update the path in my notes...
Sandman,
i'm assuming you recommend deleting that file [or at least renaming it].
i checked the plugin manager and i can't find anything missing.
i really don't want to reinstall, do you think the plugin is on the DVD?
  • 3 months later...
Man, I've been searching for this all the night, how can I add the Sky Portal button? I try what you say in this post, but I can't figure out, can you help me? please tell me exact what you did! I'm in the same problem!
Thank's in advance! (I'm good rendering in brazil [well... not good enough] but need to render an interior scene and i'm trying whit mental ray, but the portal is a basic tool, heeeeeeelp!)
  • 4 months later...
