Rfman35 Posted July 7, 2008 Share Posted July 7, 2008 (edited) Hi everyone. I'm kind of new to 3dsMax, so I build my 3d models mostly in autocad and then I import them to Max to create my render views. I'm currently working on a proyect where I have a fountain design with some curves, the problem I am having is that the curved shape doesn't import well enough in 3ds Max, I've searched around to find out what I'm doing wrong, and tried everything I have found with no good result at the end. If any one can point me to the wright direction I will greatly appreciate it. I'm attaching some images to give you an idea of my problem. As you can see, my model in AutoCad has a smooth curve shape, but when I import it to 3ds the curves get less segments resulting in a very poor render shape. Thanks for any help. Edited July 7, 2008 by Rfman35 Link to comment Share on other sites More sharing options...
Rfman35 Posted July 7, 2008 Author Share Posted July 7, 2008 Just to let everyone know. I've fixed my problem, I was putting the wrong number in Curve steps (was setting it too high), so I reduced it to 1 and everything is Ok. Gona leave the post as it might help someone else with this problem. Link to comment Share on other sites More sharing options...
helenistikyay Posted July 7, 2008 Share Posted July 7, 2008 in 3ds max, select customize, unit setup, system unit setup change the values of system unit scale see the differences Link to comment Share on other sites More sharing options...
SandmanNinja Posted July 7, 2008 Share Posted July 7, 2008 File -> File Link Manager -> Presets If you don't have one for AutoCAD, make one. I set my Maximum surface deciation for 3D Solids to a much smaller value (shift the decimal 1 place). This will help keep your circles nice and round. Link to comment Share on other sites More sharing options...
Antisthenes Posted July 7, 2008 Share Posted July 7, 2008 SATout import in rhinoceros and then export as nurbs format IGES and open that in max and you should have your true curves remain is how i have done it to me segments, steps, facets, smoothing are unacceptable methods to translate my models threw Link to comment Share on other sites More sharing options...
