Brute Guy Posted July 7, 2008 Share Posted July 7, 2008 Hi, I am making a sculpture similar to this texture (see picture below). I tried to replaicate this surface in Rhino by just adjusting the vertical height of randomly places points within a rectangle boundary, then joining them with splines, and planar surfacing all the curves. This worked well however took a long time. I'd like to create a more dense surface, however my previous technique took ages. Could anyone suggest a better technique for achieving this, my initial thoughts were to somehow under export a curved IGES surface which would faccet naturally, but I have had little success so far? Thanks Marc Link to comment Share on other sites More sharing options...
AJLynn Posted July 7, 2008 Share Posted July 7, 2008 Moved to correct forum. My suggestion would be to use other software, since Rhino is only good at curvy stuff. Link to comment Share on other sites More sharing options...
Nic H Posted July 7, 2008 Share Posted July 7, 2008 use max make plane noise modifier edit poly fiddle with verts 5 min job Link to comment Share on other sites More sharing options...
neko Posted July 7, 2008 Share Posted July 7, 2008 Moved to correct forum. My suggestion would be to use other software, since Rhino is only good at curvy stuff. that's funny......somebody is going to be very upset when/if he reads that. Link to comment Share on other sites More sharing options...
AJLynn Posted July 7, 2008 Share Posted July 7, 2008 I do what I can. Link to comment Share on other sites More sharing options...
Brute Guy Posted July 7, 2008 Author Share Posted July 7, 2008 Cheers for suggestions, and appologies for the incorrect threading. Marc Link to comment Share on other sites More sharing options...
Fran Posted July 7, 2008 Share Posted July 7, 2008 Hi Marc, You could try creating a mesh box with refinement settings that would correspond to the size of the triangles you need. Then you could pull the points manually or use a script that does that randomly for you. I think if you Unweld the vertices of the top section, you would get the jagged contours. Or, you could create a nurbs box primative, detach the top and split it in a way that would give you the various sections. Make sure the top surfaces stay at degree 2. Then when you pull control points, the edges will stay straight. Link to comment Share on other sites More sharing options...
Claudio Branch Posted July 7, 2008 Share Posted July 7, 2008 5 min job I find this excessive... Link to comment Share on other sites More sharing options...
Antisthenes Posted July 7, 2008 Share Posted July 7, 2008 rhino would kick as at such simple boxy stuff i grantee with accuracy and speed not achievable in some modifier to get it exactly as shown given you know the height differences of the peaks and the valleys. Link to comment Share on other sites More sharing options...
Claudio Branch Posted July 7, 2008 Share Posted July 7, 2008 use max make plane edit poly fiddle with verts 5 min job under 5 minutes... Link to comment Share on other sites More sharing options...
Antisthenes Posted July 7, 2008 Share Posted July 7, 2008 that's funny......somebody is going to be very upset when/if he reads that. naa, just easy to prove wrong because he doesn't have the direct experience, thus the reason he misstates the facts Link to comment Share on other sites More sharing options...
Claudio Branch Posted July 7, 2008 Share Posted July 7, 2008 so when does my super model show up? Link to comment Share on other sites More sharing options...
AJLynn Posted July 7, 2008 Share Posted July 7, 2008 OMFG I was joking, I know you can do straight lines in Rhino. Link to comment Share on other sites More sharing options...
Fran Posted July 7, 2008 Share Posted July 7, 2008 OMFG I was joking, I know you can do straight lines in Rhino. Permission to laugh now Sir. Link to comment Share on other sites More sharing options...
Antisthenes Posted July 7, 2008 Share Posted July 7, 2008 lol i forgot but i was so busy partying that i excuse myself i will come threw Link to comment Share on other sites More sharing options...
Claudio Branch Posted July 7, 2008 Share Posted July 7, 2008 Great. I need a good reason to learn another modeling app... Link to comment Share on other sites More sharing options...
AJLynn Posted July 7, 2008 Share Posted July 7, 2008 Don't bother. Anything you're going to actually use Rhino for, you can do in Sketchup and/or Max. Link to comment Share on other sites More sharing options...
Brute Guy Posted July 7, 2008 Author Share Posted July 7, 2008 Firstly, thankyou for all your input, as the sum of your feedback has helped me achieve what I set out to learn. Below is my result, I know it differs to the initial aim, however I still need to make the traingles a little more random. I decided to apply a noise mod at verticies level after converting to editable mesh. This didn't give me the randomnes I so desired, so, I begun individually moving the points as pictured in the red circle. Is it that I'm incorrectly utilising the noise mod, or is there a mod that will do what i'm doing by hand? Kind regards Marc Link to comment Share on other sites More sharing options...
jackb602 Posted July 7, 2008 Share Posted July 7, 2008 I don't know if you have access to Cinema, but this definitely took less than 5 minutes with the Set Point Value tool. No need to manually move points unless you want to. Link to comment Share on other sites More sharing options...
Sawyer Posted July 7, 2008 Share Posted July 7, 2008 Took 1 min in max: Box with: Subdivide edit poly (select top faces) Displacement (noise map) smooth. Link to comment Share on other sites More sharing options...
AJLynn Posted July 7, 2008 Share Posted July 7, 2008 I think we have a winner Link to comment Share on other sites More sharing options...
Antisthenes Posted July 7, 2008 Share Posted July 7, 2008 Don't bother. Anything you're going to actually use Rhino for, you can do in Sketchup and/or Max. we disagree, we can leave it at that or we can go head to head with strengths and weaknesses of the products we best know that will be educational for everybody else (free of assumptions evaluation interpretation judgment) and it really doesn't matter do what works for you if you don't appreciate me offering my advise in the sketchup or max sub forum what are you doing? Link to comment Share on other sites More sharing options...
Fran Posted July 7, 2008 Share Posted July 7, 2008 Well Sawyer, I opened Max up for nothing. Link to comment Share on other sites More sharing options...
Nic H Posted July 7, 2008 Share Posted July 7, 2008 i think clearing the smoothing groups after you are done will give you a sharper result as well press '4' in edit poly then scroll down to smoothing groups and 'clear all' this will keep it sharp, if you want a slight chamfer/highlight press '2' (edge mode) then - Ctrl A (select all) and then chamfer a tiny bit. Link to comment Share on other sites More sharing options...
Fran Posted July 7, 2008 Share Posted July 7, 2008 (edited) Oh wait. In order to keep the edges level, you might be better off pulling the vertices manually. If you create a chamfer box with length and width segments at 5, then convert to Editable Mesh, then clear the smoothing for the top polys within the chamfers. Then you can pull some points in vertex mode to roughly approximate your facets. Then Tessellate the selected polys in Face-Center mode and you will have more complex facets done for you. Edited July 7, 2008 by Fran different solution Link to comment Share on other sites More sharing options...
